Nexus 7 10W Adapter and Cable Adapt, recharge, and go further with your Nexus 7 - Convenient detachable USB cable connects your Nexus 7 to the 10W adapter - Auto current detection adjusts to local standards and grids worldwide - Extra compact and light for an easy fit anywhere at home and on the move- Complete peace of mind when using your Nexus 7 as the battery never runs out! Shop × Modal header Technology keeps getting more compact and more convenient, but is still held back by the need to lug around a clunky power adapter to recharge devices. No more. Take power into your hands with a slim and compact adapter that works with almost every portable PC out there, plus takes in smartphones and tablets thanks to a dedicated USB charging point. Just drop it in your bag or even pocket and get going – no need to carry anything else, as power is always within easy reach. Model Number : N50 > N50-AS031C N50-123456 N50-234567 Compatible ModelNexus 7 / ME171Dimensions45mm*25mm*45mm (wo plug dimension)Weight150 +/- 10gColorBlackPowerInput: 100-240V, 0.3AOutput: 5.0V/2A,10WContentsAdapter*1Cable*1 (90cm) × I confirm, please take me there. Cancel
