36W Car Charger
    Product Image
    Power to go!
    - Reliable power source for your laptop device in the car
    - Compact design for power on the go
    - Provides a seamless power solution, now on the way to any destination!
      Car charger for Eee PC
      The ASUS Slim Car Charger is the ultimate mobile charging solution for your laptop. Plug it in, and you don’t have to worry about your laptop running out of power during long distance car journeys. A simple hook up with your car’s A/C adapter, and you can keep any laptop easily charged while out and about.
      Model Number : N50 >
      • Color
        Black
      • Dimensions
        85(L) x 35(W) x 25(H) mm
      • Weight
        0.352 kg
      • Power
        Input: 12Vdc 5A
        Output: 12Vdc 3A
