Make better use of your time and take advantage of a car's readily available power to continue working on and charge up almost any portable device. Connect to the 12V lighter receptacle via the included plug set, attach either the device power adapter or USB port to the charger, and get where you're going while working and with the battery nice and full. Saves time, keeps devices performing on the road, and prevents awkward empty battery moments without forcing you to hunt around for a wall socket.
Multi-purpose Combo Car Charger Details
1. 90W Charger Kit
2. Lighter-Plug Charger
3. ASUS Pad 18W Charger Kit
4. Multiple changeable plugs
Compact and compatible with virtually all mobile devices: smartphones, notebooks, Eee PCs, ultrabooks, ASUS pads, and even Padfone!
Highly portable
USB device charger
Multiple plugs
Extra-slim
*Wattage
ratings for your device can be found on the power supply or product underside
