Support
Having problem after you bought a product? You can find driver, manual download, and FAQ on ASUS Customer Service website. To provide you the best service ASUS provides you different ways to make a contact with us as well.
more
0
    Essence One DSD Upgrade Kit
    Product Image
    Upgrade your Xonar Essence One series with native Direct-Stream Digital (DSD) 2.8MHz support through DSD over PCM (DoP)
    • Solder-free EEPROM upgrades your Essence One with native Direct-Stream Digital (DSD) support via DSD over PCM (DoP)
    • Two additional op-amps for easy tonal customization
      Easy DSD upgrade for Essence One devotees
      Do you own an ASUS Essence One DAC? Now you can add native DSD support with a simple-to-fit upgrade kit! The package includes one EEPROM chip for the upgrade to DSD 2.8MHz support and the upgrade process is straightforward: just the EEPROM into the socket — no soldering required! DSD 2.8MHz format delivers 64 times (64X) the sampling rate of traditional compact disc (CD) recordings.
      Profound Musicality
      The package includes two MUSES 02 operational amplifiers (op-amps). MUSES 02 op-amps are the world’s first op-amps to be manufactured with high-purity oxygen-free copper interconnects and the result is true-to-life tonality, spacious sound and stunning vocals.
