EAH2400PRO MAGIC/HTP/256M
    Full support for DirectX® 10 with 0dB silent cooling solution!
    - 0dB noiseless ASUS Silent Cooling Solution
    - HDCP Compliant
    - Built for Microsoft® Windows Vista™
      Product Image
      ASUS Exclusive Innovations
      ASUS Features
      HDCP Compliant:
      Allow playback of HD DVD, Blu-Ray Disc and other protected content at HD resolutions
      ASUS Splendid:
      Watching movies on PC is as good as on Top-of-the-line consumer television
      ASUS Video Security Online:
      Keep an eye on your home at all times no matter where you are
      ASUS Gamer OSD:
      Real-time overclocking during games
      ASUS SmartDoctor:
      Your Intelligent hardware protection and overclocking tool
      Graphics GPU Features
      Powered by ATI RADEON® HD2400PRO GPU
      Full support for Microsoft DirectX® 10 support and Shader Model 4.0 enables stunning and complex special effects
      180 million transistors on 65nm fabrication process
      ATI Avivo™ HD Technology
      Enjoy hardware based H.264/VC-1 decoding of Blu-ray™ and HD DVD movies on your computer (Recommend used in a system with an adequate CPU such as a dual core with clock greater than 2 GHz.)
      OpenGL®2.0 support
      Single dual-link DVI output which supports 2560 x 1600 at 60Hz resolution displays
      I/O Specifications
      PCI-Express
      TV-Out
      HDTV-out
      DVI-I
      VGA
      HDCP Compliant
      Maximum Effective HyperMemory
      System memory
      256MB
      512MB
      1GB
      2GB
      XP
      Not supported
      512MB
      512MB
      512MB (XP-32bit)
      1GB (XP-64bit)
      Vista
      Not supported
      320MB
      512MB
      1GB
      *SYSTEM FAN in chassis is recommended for using the Silent graphics card. For the best heat dissipating results, please place the PC in a location with good ventilation.
