ENGTX560 Ti DC2 TOP/2DI/2GD5
    Product Image
    ASUS GTX 560 Ti DirectCU II TOP overclocked graphics card with 2GB memory
    • Top-selected and overclocked to 900MHz, 80MHz higher than reference for faster and smoother performance
    • Speed up heat dissipation with doubled airflow via exclusive DirectCU dual fan design
    • Pump up graphics performance with Super Alloy Power delivering a 15% performance boost, 2.5 longer lifespan and 35C cooler operation
    • GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface
    Product Image
    Raging Cool Power For the Win!
    ASUS Exclusive Innovation
    Super Alloy Power
    Super Alloy Power
    Super Alloy Power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35°C cooler operation and 2.5 times longer lifespan.
    Super Alloy Power
    DirectCU
    DirectCU II
    Based on ASUS DirectCU architecture, which uses copper heat pipes in direct contact with the GPU to speed up heat dissipation for over 20% cooler performance, DirectCU II takes cooling further with twin 80mm fans for doubled airflow.
    GPU
    900MHz Overclocked!
    Factory overclocked to Performs at an incredible 900MHz, 80MHz faster than stock performance, resulting in higher frame rates in games.
    GPU Tweak
    GPU Tweak
    GPU Tweak provides a professional yet intuitive graphics tuning interface for real time card adjustment and monitoring
    Graphics GPU Features
    NVIDIA GeForce
    Powered by NVIDIA® GeForce® GTX560 Ti
    NVIDIA Force with CUDA
    NVIDIA® CUDA™
    Unlocks the power of GPU’s processor cores to accelerate the most demanding system tasks.
    NVIDIA SLI Ready
    NVIDIA® SLI™
    Supports multi-GPU technology for extreme performance ode
    PhysX by NVIDIA
    NVIDIA PhysX™
    Delivers dynamic visual effects like blazing explosions, reactive debris, realistic water, and lifelike characters.
    NVIDIA 3D Vision Ready
    NVIDIA® 3D Vision™
    Immersive yourself in 3D gaming world
    Full DirectX 11 Support
    DirectX® 11 Done Right
    Brings new levels of visual realism to gaming on the PC and get top-notch performance
    Compatible with Windows7
    Microsoft® Windows® 7 Compatible
    Enable PC users to enjoy an advanced computing experience and to do more with their PC
    I/O Ports Highlight
    IO Ports
    Model Number : N50 >
    • Graphics Engine
      NVIDIA GeForce GTX 560 Ti
    • Bus Standard
      PCI Express 2.0
    • Video Memory
      GDDR5 2GB
    • Engine Clock
      900 MHz
    • CUDA Core
      384
    • Shader Clock
      1800 MHz
    • Memory Clock
      4008 MHz ( 1002 MHz GDDR5 )
    • RAMDAC
      400 MHz
    • Memory Interface
      256-bit
    • Resolution
      D-Sub Max Resolution : 2048x1536
      DVI Max Resolution : 2560x1600
    • Interface
      D-Sub Output : Yes x 1 (via DVI to D-Sub adaptor x 1)
      DVI Output : Yes x 2 (DVI-I)
      HDMI Output : Yes x 1 (via Mini HDMI to HDMI adaptor x 1)
      HDCP Support : Yes
    • Accessories
      1 x Mini HDMI to HDMI adaptor
      1 x DVI to D-Sub adaptor
      2 x Power cable
    • Power Consumption
      up to 225W2 additional 6 pin PCIe power required
    • Software
      ASUS Driver & Utilities. GPU Tweak
    • ASUS Features
      DirectCU Series
      TOP Series
      Super Alloy Power
    • Dimensions
      10.16 " x 5.12 " Inch
