Extreme AX850XT/HTD/256M
    Product Image
    - ASUS GameFace Live
    - ASUS VideoSecurity Online
    - ASUS OnScreenDisplay
    - High-Definition TV output
    - Hottest 3D games bundled
      ASUS Extreme AX850XT Series
      ASUS Extreme AX850XT series is equipped with exclusive ASUS innovations and ATI RADEON™X850XT VPU. Extreme AX850XT series delivers state-of-the-art cinematic resolution for demanding 3D applications. It advances High-Definition Gaming with blockbuster features, such as ASUS GameFace Live, VideoSecurity Online, OnScreenDisplay (OSD), and ATI SMARTSHADER™ SMOOTHVISION™ 3Dc™ ASUS Extreme AX850XT series is a complete solution for the new PCI-Express market.
      Why ASUS is Better?
      ASUS GameFace Live for real-time video/audio communication.
      ASUS VideoSecurity Online for building a private security system.
      ASUS OnScreenDisplay (OSD) allows adjusting various display settings without leaving the game.
      High-Definition TV output for big screen gaming or presentations.
      DVI output for easy connectivity to digital flat panel display.
      Hottest 3D games bundled including Joint Operations & Xpand Rally
      Chipset Feature
      SMARTSHADER™HD: full hardware acceleration of Microsoft DirectX 9.0 programmable vertex and pixel
      shaders in hardware.
      SMOOTHVISION™HD: 2X/4X/6X anti-aliasing models.
      VIDEOSHADER™HD: seamless integration of pixel shaders and video in real time.
      Hyper Z™HD: 3-level hierarchical Z-Buffer with early Z test. Lossless Z-Buffer compression (up to 48:1)
      3Dc™: high quality 4:1 Normal Map compression; works with any two-channel data format.
      CATALYST™ Software Suites
      Model Number : N50 >
      • Graphics Engine
        ATI Radeon X850XT
      • Video Memory
        256 MB DDR3
      • Engine Clock
        520MHZ
      • Memory Clock
        1.08GHZ (540MHZ DDR3)
      • RAMDAC
        400MHz
      • Bus Standard
        16 lanes PCI Express
      • Memory Interface
        256 bit DDR3
      • D-Sub Output
        Yes
      • HDTV Output (YPbPr)
        S-Video to HDTV
      • TV Output
        S-Video to Composite
      • DVI Output
        DVI-I
      • Dual VGA Output
        Yes
      • Adapter/Cable Bundled
        1. DVI-VGA Adapter
        2. 7 pin S-Video to HDTV Cable
        3. Svid Cable
        4. RCA Composite Cable
        5. Power Cable
      • Software Bundled
        1. Joint Operations
        2. Xpand Rally
        3. ASUS DVD XP
        4. Power Director 3
        5. Media Show
        6. ASUS Driver and Utilities
