Extreme AX850XT PE/2DHTV/256M
    Product Image
    - ASUS GameFace Live
    - ASUS VideoSecurity Online
    - ASUS OnScreenDisplay
    - High-Definition TV output
    - 2 DVI outputs
    - Hottest 3D games bundled
      ASUS Extreme AX850XT Platinum Edition
      ASUS Extreme AX850XT Platinum Edition is equipped with exclusive ASUS innovations and ATI RADEON X850XT Platinum Edition VPU. Extreme AX850XT Platinum Edition delivers state-of-the-art cinematic resolution for demanding 3D applications. It advances High-Definition Gaming with blockbuster features, such as ASUS GameFace Live, VideoSecurity Online, OnScreenDisplay (OSD), and ATI SMARTSHADER SMOOTHVISION 3Dc ASUS Extreme AX850XT Platinum Edition is a complete solution for the new PCI-Express market.
      Why ASUS is Better?
      ASUS GameFace Live for real-time video/audio communication.
      ASUS VideoSecurity Online for building a private security system.
      ASUS OnScreenDisplay (OSD) allows adjusting various display settings without leaving the game.
      High-Definition TV output for big screen gaming or presentations.
      2 DVI outputs for easy connectivity to digital flat panel display.
      Hottest 3D games bundled including Joint Operations & Xpand Rally
      Chipset Feature
      SMARTSHADER™ HD: full hardware acceleration of Microsoft DirectX9.0 programmable vertex and pixel shaders in hardware.
      SMOOTHVISION™ HD: 2X/4X/6X anti-aliasing models.
      VIDEOSHADER™ HD: seamless integration of pixel shaders and video in real time.
      Hyper Z™ HD: 3-level hierarchical Z-Buffer with early Z test. Lossless Z-Buffer compression (up to 48:1)
      3Dc™: high quality 4:1 Normal Map compression; works with any two-channel data format.
      CATALYST™ Software Suites
      Model Number : N50 >
      • Graphics Engine
        ATI Radeon X850 XT Platinum Edition
      • Video Memory
        256 MB DDR3
      • Engine Clock
        540MHZ
      • Memory Clock
        1.18GHZ (590MHZ DDR3)
      • RAMDAC
        400MHz
      • Bus Standard
        16 lanes PCI Express
      • Memory Interface
        256 bit DDR3
      • D-Sub Max Resolution
        2048x1536
      • D-Sub Output
        VGA Output (per DVI To VGA Adapter) Standard 15-pin D-s
      • HDTV Output (YPbPr)
        S-Video to HDTV
      • TV Output
        S-Video to Composite
      • Video Input
      • DVI Output
        DVI-I
      • Dual DVI Output
        Yes
      • Dual VGA Output
        Yes
      • Adapter/Cable Bundled
        1. 2* DVI-VGA Adapter
        2. 9 pin S-Video to HDTV Cable
        3. 9 pin S-Video to Composite VIVO
        4. Svid Cable
        5. RCA Composite Cable
        6. Power Cable
      • Software Bundled
        1. Joint Operations
        2. Xpand Rally
        3. ASUS DVD XP
        4. Power Director 3
        5. Media Show
        6. ASUS Driver and Utilities
