Extreme N6800LE/HTD/256M
    Product Image
    -ASUS GameFaceLive
    - ASUS Video Security Online
    - ASUS OnScreenDisplay (OSD)
    - Diversified displays connectivity
    - The hottest game bundled
      Experience the explosive super speed of PCI-Express with ASUS Extreme N6800LE
      ASUS Extreme N6800LE equips the newest ASUS-specific award-winning features and nVIDIA® GeForce 6800LE graphics processing unit (GPU). ASUS Extreme N6800LE is positioned on the enthusiasts’ products and the most complete solution for the 3D and video application market.
      ASUS Features:
      The hottest game, Joint Operations, is bundled
      ASUS GameFace™ Live: The World's first multiplayer audio and video chatting solution for PC games. It enables simultaneous connection up to 8 players.
      ASUS Video Security™ Online: Whether you're online or not, ASUS VideoSecurity Online provides you a flexible and economical security system. It can easily turn your computer into your own security server.
      ASUS OnScreenDisplay (OSD): OSD allows you to instantly adjust various display settings in almost any PC game without leaving the game.
      Diversified displays connectivity (HDTV, DVI, Dual VGA, DVI+VGA, DVI+TV-out), high definition TV compatible for excellent visual experience on mega screen.
      Superior Cooling Solution: Equipped with stylish copper fansink for best cooling efficiency.
      Graphics Chip Key Features:
      Powered by the world’s most powerful GPU - nVidia® GeForce 6800LE
      NVIDIA SLI Multi-GPU ready - Dramatically scales performance by allowing two graphics cards to run in parallel.
      NVIDIA® CineFX™ 3.0 engine – Full support for Microsoft DirectX9.0 Shader model 3.0 enables stunning and complex special effects
      NVIDIA UltraShadow™ II technology –Enhances the performance of bleeding-edge games
      NVIDIA® Intellisample™ 3.0 technology –The industry’s fastest antialiasing delivers ultra-realistic visuals, with no jagged edges, at lightning-fast speeds
      NVIDIA nVIEW Multi-display technology - Advanced technology provides the ultimate in viewing flexibility and control for multiple monitors.
      Microsoft® DirectX 9 and OpenGL 1.5 support
      Model Number : N50 >
      • Graphics Engine
        GeForce 6800LE
      • Video Memory
        256 MB
      • Engine Clock
        350MHz
      • Memory Clock
        300MHz DDR
      • RAMDAC
        400MHz
      • Bus Standard
        PCI-Express
      • Memory Interface
        256-bit
      • D-Sub Max Resolution
        2048x1536
      • D-Sub Output
        Standard 15-pin D-sub
      • TV Output
        HDTV & Composite
      • 2nd VGA Output
        Yes
      • Adapter/Cable Bundled
        TV out cable supporting HDTV
        composite DVI-to-2nd VGA adaptor
      • Software Bundled
        Joint Operations
        ASUS DVD XP
        Power Director
        Media Show
        ASUS Utilities & Driver
