ROG Front Base
    ROG Front Base
    Dual-Bay Gaming Panel
    • Ultimate audio companion - Enjoy true-to-life gaming with awesome sound quality
    • One-click overclocking - Your one-button supply line for instant extra performance
    • Hit the button, hide your game - ‘Escape Mode’ instantly hides your gaming activity — any time
    • Monitor your system and control multiple fans – real-time management of the CPU cooler and up to four other case fans – and all can be controlled individually!
    • Always-on USB charger - Quick charge in sleep, hibernate and shutdown modes
      Product Image
      Monitor and control, then rush into action 4-inch display with an intuitive interface Ultimate sound and real-time gaming control features
      ROG FRONT BASE
      To win, you must take control – control of the battlefield and your equipment. ROG Front Base Dual-Bay Gaming Panel gives you fingertip control over your equipment, so you can concentrate on controlling the battlefield!
      Ultimate sound and real-time gaming controls all in one place
      This must-have weapon acts as a clever command center to match your ROG motherboards for a complete gaming experience! Front Base Dual-Bay Gaming Panel provides instant access to five equalization modes with the Quick EQ Switch, and use the included Hi-Fi-quality AAFP cable with motherboards that include SupremeFX technology for a superb audio experience with minimal noise interference. It also has great overclocking capabilities for instant performance boost and easily-accessed fan controls, system temperature displays and supports fast USB charging — even when PC is powered off. Front Base Dual-Bay Gaming Panel even features an innovative Escape Mode button that hides the gaming screen and mutes the volume, allowing users to return to the desktop in the blink of an eye.
      Secure more wins with ROG’s quick-fit gaming center
      ROG Front Base Dual-Bay Gaming Panel fits easily into dual 5.25-inch drive bays and includes a large display with an intuitive interface that’s controlled by a simple selection knob and buttons.
      • 4-inch display
      • CPU frequency
      • Fan speed display
      • Quick EQ (equalizer) mode switch
      • Temperature display
      • Headphone-out port
      • Mic-in port
      • USB 2.0 port
      • Escape Mode button
      • OC button
      • LCD power button
      • Selection knob
      Hands on: Easy 2-step installation
      Connect the ROG_EXT cable and the AAFP cable to their respective connectors on the ROG Front Base device
      Insert the other end of ROG_EXT cable and the AAFP cable through two empty 5.25-inch drive bays, as shown, and then connect them to the motherboard.
      Get instant access to five equalization modes with the Quick EQ Switch – from shooting games to sports, fiction and racing titles or high-clarity music. Whatever audio mode the game demands, the Quick EQ Switch gets you there in a beat. Combine the included Hi-Fi-quality analog-audio front-panel (AAFP) cable with motherboards that have SupremeFX technology for a very high signal quality, with low crosstalk and minimal noise interference.
      music
      shooting
      fiction
      sport
      racing
      Bundled Hi-Fi-quality AAFP cable for pure audio
      ASUS bundled AAFP cable Normal built-in cable
      Get a real-time CPU-performance boost with a single click of the OC button. It’s overclocking done the smart way – instantly and any time!
      Taking cover couldn’t be easier! This innocuous little button masks a great little secret – just press ‘Escape Mode’ button to instantly hide the gaming screen, mute the volume and return to the desktop.
      Click
      Instant cooling or zero noise? You’re always in complete command!
      When the action hots up, keep your PC cool with Front Base Gaming Panel’s real-time management of the CPU cooler and up to four other case fans – and all can be controlled individually! With a quick turn of the selection knob, you can turn up the RPM speeds for extra cooling or hush the fans to reduce noise and save power.
      Charge forward with strong system information at your side
      The 4-inch display provides an at-a-glance view of key system information, including fan speeds, CPU and motherboard temperatures, and CPU frequency speed. If something important needs attention, you’ll know right away.
      Always-on USB charger!
      Use the built-in USB port to charge your smart devices even when the PC is asleep, hibernating or powered off.
      • Smart Phone
      • Tablet
      • iProduct
             Compatible Models
      Chipset Motherboard CPU Frequency Display Fan Speed Control Fan Speed Display CPU & MB Temperature Display Quick EQ Switch One-Click Overclocking Escape Mode
      Intel Z170 Maximus VIII Series Supported Supported Supported Supported Ready in 2016 Q3 Supported Supported
      Intel Z170 Z170 Pro Gaming Supported Supported Supported Supported Supported Supported Supported
      Intel H170 H170 Pro Gaming Supported Supported Supported Supported Supported Supported Supported
      Intel B150 B150 Pro Gaming Series Supported Supported Supported Supported Supported Supported Supported
      Intel X99 Rampage V Extreme Supported Supported Supported Supported Supported Supported Supported
      Intel X99 Strix X99 Gaming Supported Supported Supported Supported Supported Supported Supported
      AMD A88X CrossBlade Ranger Supported Supported Supported Supported Supported Supported Supported
      Intel Z97 Maximus VII Series Supported Supported Supported Supported Supported Supported Supported
      Intel Z87 Maximus VI Series Supported Supported Supported Supported Supported Supported Supported
      Intel X79 Rampage IV Black Edition Supported Supported Supported Supported Supported Supported Supported
      Back top
