Xonar D1
    Product Image
    Dolby Home Theater Technologies & Richest Gaming Audio Effects for best PC audio upgrade
    - 35 times clearer then on-board audio
    - Supports latest DS3D GX2.0 for gaming on Vista & XP
    - Dolby home theater technologies
    - Low-profile bracket bundled
    - S/pdif connect to vga cards for hdmi output
    Product Image
    Complete Dolby Home Theater technologies
    Inheriting from DX and D2X, Xonar D1 also provides complete valuable Dolby Home Theater technologies for games and all home entertainments:
    Dolby Digital Live:
    Real-time 5.1 Dolby Digital surround sound encoders
    Dolby Pro-Logic IIx:
    Converts stereo or 5.1 sounds to seamless 7.1 surround soundfield
    Dolby Headphone:
    Delivers a realistic and spacious 2-to-5.1 surround or 3D positional soundfield over any set of stereo headphones
    Dolby Virtual Speaker:
    Simulates a highly realistic 5.1-speaker surround sound listening environment from as few as two speakers
    Supports latest DS3D GX 2.0 for gaming on Vista & XP
    DS3D GX 2.0 not only revives EAX and DirectSound effects in games on Windows Vista as GX 1.0, but also incorporates Dolby Home Theater Technologies (Dolby Virtual Speaker, Dolby Headphone, Dolby Digital Live, Dolby PrologicIIX) to provide best gaming audio experience.
    Innovative VocalFX makes gaming and online chat more lively and attractive
    VocalFX is an innovative voice processing technology to let your voice get into the realistic game landscape (VoiceEX) or to emulate the background scenes in online chat (ChatEX). It also allows you to change your voice pitch to disguise who you are (Magic Voice). These features dramatically increase the fun for voice communication on PC.
    Delivers about 35 times cleaner audio quality (116dB SNR) than most motherboard audio (85dB SNR)
    The noise on Xonar D1 audio card is only 1/35 (2.8%) of the noise level from most motherboard onboard audio. In addition, Xonar D1 also produces as little as 1/32 (-105dB) of the total harmonics distortion from motherboard audio does (-75dB).
    S/PDIF header for combining audio with video through a VGA card’s HDMI output
    The new S/PDIF header allows connectivity with supporting VGA cards, facilitating merged output of audio and video through a VGA card’s HDMI port. This provides a clean, simple solution for Home Theater PC builders.
    Package Contents
    Xonar D1 7.1 Channel PCI Audio Card
    Driver CD (including RMAA V6.0.6 utilities)
    Low-profile bracket
    S/PDIF TOSLINK optical adaptors *1
    Quick Start Guide
    System Requirements
    One PCI slot for the audio card
    Microsoft® Windows® Vista(32/64bit)/XP(32/64bit)/MCE2005
    Intel® Pentium®4 1.4GHz or AMD Athlon 1400 CPU or faster CPU
    >256 MB DRAM system memory
    >60 MB available HDD space for driver installation package
    CD-ROM drive (or DVD-ROM drive) for software installation
    High-quality headphones, powered analog speakers, or a Dolby Digital or DTS decoder, to enjoy the ultra-high fidelity sounds of the card
    Model Number : N50 >
    • Audio Performance
      Output Signal-to-Noise Ratio (A-Weighted) (Front-out) :
      116 dB
      Output THD+N at 1kHz (Front-out) :
      >0.00056 %(-105 dB)
      Output THD+N at 1kHz (Headphone-out) :
      >0.001 %(-100 dB)
      Frequency Response (-3dB, 24bit/96KHz input) :
      10 Hz to 48 KHz
      Output/Input Full-Scale Voltage :
      Unbalanced Output : 2 Vrms (5.65 Vp-p)
    • Bus Compatibility
      PCI
    • Chipset
      Audio Processor :ASUS AV100 High-Definition Sound Processor (Max. 192KHz/24bit)
    • Sample Rate and Resolution
      Analog Playback Sample Rate and Resolution :
      44.1K/48K/96K/192KHz @ 16bit/24bit
      Analog Recording Sample Rate and Resolution :
      S/PDIF Digital Output :
      ASIO Driver Support :
    • Connectivity
      Analog Output
      4 x 3.5 mm jack (1/8") (Front out/Side out/Center-Subwoofer out/Rear out)
      Analog Input
      1 x 3.5 mm jack (1/8") (Line-in/ Mic-in combo)
      Digital
      1 x S/PDIF out (1 x Optical (Toslink)/(combo with analog in))
      1 x Front-Panel Header
      1 x Aux-in (4-pin header)
    • Special Features
      Dolby® Technologies : Dolby® Digital Live/Dolby® Headphone /Dolby® Virtual Speaker /Dolby® Pro-Logic II
      Smart Volume Normalizer™
      FlexBass™
      10 -band Equalizer
      27 Environment Effects
      GX 2.5 Game Audio Engine
      VocalFX™
    • Accessories
      S/PDIF adaptor x 1
      Low -profile Bracket x 1
    • Note
      RightMark Audio Analyzer 6.0.6:
      Easy but powerful software intended for testing the quality of audio equipments
