Xonar D2/PM Ultra Fidelity 7.1 PCI Sound Card with Complete Dolby®/DTS® Sound Technologies - Unparalleled SNR up to 118db Audio Quality - High Definition Audio Processing at 192KHz/24Bit Sampling Rates - ALT technology: Legally backup digital music into non-protected MP3/WMA files - Dolby and DTS for Complete Digital Home Experience Shop × Modal header Ultra Fidelity 7.1 PCI Sound Card with Complete Dolby®/DTS® Sound Technologies ASUS Xonar D2 audio card, dedicated to be the best audio card for gaming and home entertainments, provides unprecedented 118dB In/Out SNR audio quality and features for games, music, and movies. Combining 192k/24bit ultra fidelity input and output at with a suite of Dolby and DTS sound technologies and abundant valuable software, the Xonar D2 is well designed to upgrade your PC to a powerful and high-quality Home Entertainment Center, which you will never have with onboard audio or other sound cards! ASUS Features Unprecedented SNR Up to 118db reaching the limit of PC sound clarityHigh-definition audio processing at 192KHz/24Bit for all Input and outputsVersatile Dolby/DTS Audio Technologies for Game, Music, and VideoAccurate 3D sound positioning and hardware acceleration for PC gamingLegally backup your digital music with Dolby Headphone or Dolby Virtual Speaker effects addedReal-time DDL and DTS Connect encoders for amazing gaming and surround sounds over your Home Theater System Model Number : N50 > N50-AS031C N50-123456 N50-234567 Audio PerformanceOutput Signal-to-Noise Ratio (A-Weighted) (Front-out) :118 dBOutput THD+N at 1kHz (Front-out) :>0.0004 %(-108 dB)Frequency Response (-3dB, 16bit/44.1KHz input) :10 Hz to 46 KHzOutput/Input Full-Scale Voltage :Unbalanced Output : 2 Vrms (5.65 Vp-p)Bus CompatibilityPCIChipsetAudio Processor :ASUS AV200 High-Definition Sound Processor (Max. 192KHz/24bit)Sample Rate and ResolutionAnalog Playback Sample Rate and Resolution :44.1K/48K/88.2K/96K/176.4K/192KHz @ 16bit/24bitAnalog Recording Sample Rate and Resolution :44.1K/48K/88.2K/96K/176.4K/192KHz @ 16bitS/PDIF Digital Output :44.1K/48K/88.2K/96K/176.4K/192KHz @ 16bit/24bitS/PDIF Digital Input :44.1K/48K/88.2K/96K/176.4K/192KHz @ 16bit/24bitASIO Driver Support :44.1K/48K/88.2K/96K/176.4K/192KHz @ 16bit/24bit ConnectivityAnalog Output 4 x 3.5 mm jack (1/8") (Front out/Side out/Center-Subwoofer out/Rear out)Analog Input 2 x 3.5 mm jack (1/8") (Line-in/Mic-in)Digital1 x S/PDIF out (1 x Coaxial)1 x S/PDIF in (1 x Coaxial)1 x MIDI in/out1 x Aux-in (4-pin header)Special FeaturesDolby® Technologies : Dolby® Digital Live/Dolby® Headphone /Dolby® Virtual Speaker /Dolby® Pro-Logic II DTS® Technologies : DTS Interactive Encoder/DTS Neo:PC technologiesAccessoriesH6 extension board cable x 1DVI-to-HDMI cable x 1HDMI-to-HDMI cable x 1S/PDIF adaptor x 23.5mm-to-RCA adaptor cable (8-ch) x 4Additional MIDI card, cable, and external standard MIDI adaptor Y cable x 1NoteBundled software:● Ableton Live 6 Lite● PowerDVD 7.0● Valuable Cakewalk Sonar LE, Dimesion LE, and Project5 LE × I confirm, please take me there. Cancel
