Xonar DSX
    Product Image
    PCI Express 7.1-channel audio card
    • GX2.5 for realistic 3D gaming audio effectsts
    • DTS® Connect technology for an immersive 7.1 surround experience
    • 192k/24bit True PC Hi-Fi Enjoyment
    • Swappable OPamp socket - Tune up your own sound with ease
    • Auto-detect front-panel - best flexibility and connectivity
      Product Image
      Bring the Hi-Fi spirit to your Games, Music, and Movies
      GX 2.5 for realistic 3D gaming audio effects
      Feel opponents sneaking behind you and hear voices echo in dungeons with the ASUS-exclusive GX 2.5 gaming audio engine, which allows up to 128 different sound effects at once for a realistic 3D audio experience. It also supports the latest version of EAX® and restores surround gaming in Windows 7 with no additional software.
      DTS® Connect technology for an immersive 7.1-channel surround experience
      Consisting of DTS Neo: PC™ and DTS Interactive™ technologies, DTS® Connect brings the world’s most wanted hi-fi surround sound to your PC and turns it into a powerful multimedia center and game console.
      - Surrounded all the time - DTS Neo: PC™
      Converts any stereo signal into 7.1 channels – get the most out of your multi-channel speaker setup!
      - World's most wanted surround audio at your service - DTS Interactive™
      Turns all sound into sensational 7.1 DTS Digital surround via S/PDIF output – feed your AV receiver the best surround available!
      True 192KHz/24-bit PC hi-fi enjoyment
      Enjoy music file convertion at the highest quality with no sample rate downgrade.
      Swappable operational amplifiers - tune up your own sound
      A design once only seen on hi-end audio equipment is now presented on the Xonar DSX 7.1. It allows you to customize your sound with no soldering, and thus create your favorite listening experience with ease.
      Automatic jack-sensing front-panel output
      The Intel® HDA-compatible front-panel header automatically switches output between the back and the front of the case once speakers/headphones are plugged in. Never again will you be bothered by the need to change connection settings manually!
      Model Number : N50 >
      • Audio Performance
        Output Signal-to-Noise Ratio (A-Weighted) (Front-out) :
        107 dB
        Input Signal-to-Noise Ratio (A-Weighted) :
        100 dB
        Output THD+N at 1kHz (Front-out) :
        0.0017 %(-95 dB)
        Input THD+N at 1kHz :
        0.0017 %(-95 dB)
        Frequency Response (-3dB, 24bit/96KHz input) :
        10 Hz to 48 KHz
        Output/Input Full-Scale Voltage :
      • Bus Compatibility
        PCI Express
      • Chipset
        Audio Processor :ASUS AV66 High-Performance Sound Processor (Max. 192KHz/24bit)
      • Sample Rate and Resolution
        Analog Playback Sample Rate and Resolution :
        44.1K/48K/96K/192KHz @ 16bit/24bit
        Analog Recording Sample Rate and Resolution :
        S/PDIF Digital Output :
        ASIO Driver Support :
      • Connectivity
        Analog Output
        4 x 3.5 mm jack (1/8") (Front out/Side out/Center-Subwoofer out/Rear out)
        Analog Input
        1 x 3.5 mm jack (1/8") (Line-in/ Mic-in combo)
        Digital
        1 x S/PDIF out (1 x Optical (Toslink)/(combo with rear out))
        1 x Front-Panel Header
        1 x Aux-in (4-pin header)
      • Special Features
        DTS® Technologies : DTS Interactive Encoder/DTS Neo:PC technologies
        Smart Volume Normalizer™
        Xear 3D™ Virtual Speaker Shifter
        Karaoke Functions
        FlexBass™
        10 -band Equalizer
        27 Environment Effects
        VocalFX™
      • Accessories
        S/PDIF optical adaptors x 1
        Low -profile Bracket x 1
      • Dimensions
        64.4 x 167.64 mm ( L x W )
