Xonar U1 Audio Station
    Product Image
    The Best Portable PC Audio Upgrade Solution for Laptops or Desktops
    - Stylish design & crisp clear audio quality
    - Complete audio technologies from Dolby Studio
    - EAX and DirectSound HW Support
    - High quality headphone amplifier
    - Advanced array microphone bundled
      Product Image
      or Desktops
      Stylish External Processor
      Crisp Clear & Gaming Audio Support
      Xonar U1 transcodes any stereo source into Dolby Headphone, Virtual Speaker, and 5.1-channel Dolby Digital & Pro-Logic II surround sound. It also supports DirectSound, EAX, OpenAL for best gaming in Windows Vista and XP.
      High Fidelity Headphone Amp
      For High End Headphone Enjoyments
      Xonar U1’s built-in high-fidelity headphone amplifier achieves best listening quality with most stereo headphones (8~150 ohms @ >10mWx2):
      THD+N<0.005% @ 47mW x2/32ohms
      THD+N<0.006% @ 88mW x2/16ohms
      Dolby Home Theater Technologies
      High Quality Audio From Dolby
      Xonar U1 tanscodes stereo audio source into Dolby Headphone, Virtual Speaker, and even 5.1-channel Dolby Digital and Pro-Logic II surround sound output.
      Array Microphone Bundled
      Best for VoIP
      The bundled advanced Array MIC technology can suppress ambient noises for up-to-20 dB, leaving only front-side clear voice for VOIP applications (Skype, MSN, Google, QQ, etc.) or online gaming.
      Hardware Interface
      1. LED Indicator
      Mute: Red
      Unmute: Blue
      User features on: Flashing Blue
      2. Push down for mute/unmute
      3. Digital Rotary Volume
      4. Analog/Digital Combo Out
      5. Stereo Mic/Line-in
      Colors available
      Model Number : N50 >
      • Audio Performance
        Output Signal-to-Noise Ratio (A-Weighted):
        100 dB
        Output THD+N at 1kHz:
        0.0045% (87dB)
      • Main Chipset
        Audio Processor:
        UA100
      • Sample Rate and Resolution
        Analog Playback Sample Rate and Resolution:
        48KHz
      • I/O Ports
        Analog Output Jack:
        Analog 2 channel
        Analog Input Jack:
        Stereo recording
        Digital S/PDIF Output:
        Digital 5.1
      • Driver Features
        Operation System:
        Windows 7/Vista/XP/MCE2005
        Dolby® Technologies:
        Dolby® Headphone
        Dolby® Virtual Speaker
        Dolby® Pro-Logic IIx
        Dolby® Digital Live
        Smart Volume Normalizer™:
        Normalizes the volume of all audio sources into a constant level and also enhances your 3D sound listening range and advantages in gaming
        Xear 3D™ Virtual Speaker Shifter:
        Virtual 7.1 speaker positioning
        Magic Voice™:
        Modifies the sound of your voice, for VOIP and online chat applications
        Karaoke Functions:
        Music Key-Shifting and Microphone Echo effects
        Other Effects:
        10-band Equalier/27 Environment Effects
        DS3D GX2.5:
        DS3D GX 2.5 supports EAX gaming sound effects and DirectSound 3D hardware enhanced functions on Windows 7/Vista. (DirectX/DirectSound 3D compatible)
      • Bundled Software Utility
        Portable Music Processor utility:
        Add Dolby Headphone, Dolby Virtual Speaker (w/ Pro-Logic II), and Smart Volume Normalization processing to your digital music files
      • Accessories
        1 x S/PDIF optical adaptors
        Dolby Demo CD
        1 x Driver CD
        1 x Quick Start Guide
      • Size (Width x Height)
        72.6(Diameter) x 52.5
      • Note
        Bundled with "Array Microphone":
        Reducing environmental background sounds and noises; keeping your front side voice input as clean as possible
