Xonar Xense
    Product Image
    ASUS Xonar Xense Premium Gaming Audio Set (Acoustics powered by Sennheiser)
    - Triumph over your opponents in FPS games with precision acoustics
    - Embrace clarity for the win with EMI shields and 118dB SNR
    - Fight to the end with ergonomic headset design
    Product Image
    ASUS and Sennheiser Deliver World’s First Total Audio Solution Optimized for First Person Shooters - Xonar Xense
    The new ASUS Xonar Xense One and Sennheiser PC 350 Xense Edition package is the result of cooperation between ASUS and premier personal audio maker, Sennheiser. Xonar Xense is a perfectly matched combination of cutting edge audio card and superior quality headphones that reinvents immersive sound for serious gamers. The gaming audio set creates unbeatable sonic experiences in PC gaming that are sure to be appreciated by hardcore gamers keen on competitive online play.
    • Designed as a whole is the best way to get ultimate audio performance
    • Powerful headphone amplifier and matched high-impedance driver secure FPS-optimized sound positioning and dynamics
    • No footsteps missed in front of the 118dB SNR sound clarity brought by EMI shield and studio-standard 6.3mm audio jack
    • Stylish full-stainless steel design matches the earcup cover of Sennheiser headset
    Fight to the end with the ergonomic headset
    Pro gamers’ long-hour usage catered by excellent headset ergonomics
    New Gain Level perfectly tuned up for the headset
    To ensure the supreme performance of Sennheiser PC 350 Xense Edition, ASUS and Sennheiser engineers co-worked and tuned up a new Gain Level perfect for Sennheiser PC 350 Xense Edition sound performance.
    Sennheiser PC 350 Xense Edition headset
    General
    Cable length 3m (9.8 feet)
    Connector plugs 2 x 6.3mm
    Speaker type Dynamic, 38mm, Nd magnet
    Frequency response 10 – 26,000Hz
    Impedance 150Ω
    Distortion less than 0.1%
    Microphone
    Frequency response 50 – 16,000Hz
    Pick-up pattern Noise canceling
    Sensitivity -38dBV at 94dBSPL
    Model Number : N50 >
    • Audio Performance
      Output Signal-to-Noise Ratio (A-Weighted) (Front-out) :
      118 dB
      Output THD+N at 1kHz (Front-out) :
      >0.00039 %(-108 dB)
      Output THD+N at 1kHz (Headphone-out) :
      >0.0019 %(-94 dB)
      Frequency Response (-3dB, 16bit/44.1KHz input) :
      10 Hz to 46 KHz
      Output/Input Full-Scale Voltage :
      Unbalanced Output : 2 Vrms (5.65 Vp-p)
    • Bus Compatibility
      PCI Express
    • Chipset
      Audio Processor :ASUS AV100 High-Definition Sound Processor (Max. 192KHz/24bit)
    • Sample Rate and Resolution
      Analog Playback Sample Rate and Resolution :
      44.1K/48K/88.2K/96K/176.4K/192KHz @ 16bit/24bit
      Analog Recording Sample Rate and Resolution :
      S/PDIF Digital Output :
      ASIO Driver Support :
    • Connectivity
      Analog Output
      4 x 3.5 mm jack (1/8") (Front out/Side out/Center-Subwoofer out/Rear out/via Splitter Cable)
      1 x 6.3 mm jack (1/4") Headphone out
      Analog Input
      1 x 3.5 mm jack (1/8") (Line-in/ Mic-in combo)
      Digital
      1 x S/PDIF out (1 x Optical / Coaxial combo)
      1 x Front-Panel Header
      1 x Aux-in (4-pin header)
    • Special Features
      Dolby® Technologies : Dolby® Digital Live/Dolby® Headphone /Dolby® Virtual Speaker /Dolby® Pro-Logic II
      Smart Volume Normalizer™
      Karaoke Functions
      FlexBass™
      GX 2.5 Game Audio Engine
      VocalFX™
    • Accessories
      6.3mm to 3.5mm stereo adapter x 1
      7.1 channel audio splitter cable x 1
