Support
Having problem after you bought a product? You can find driver, manual download, and FAQ on ASUS Customer Service website. To provide you the best service ASUS provides you different ways to make a contact with us as well.
more
    Extreme Slim Ext DVD-RW Drive
    Product Image
    Thin size, wide DVD utility
    • Ultra slim profile at 14mm, the thinnest external DVD available / Ultra thin 14mm profile goes everywhere and weighs next to nothing
    • Eye-catching design combines durable brushed metal surface with shiny side panels / Splendid brushed metal and glossy case design augment your PC of choice
    • Convenient of USB 2.0 eliminates the need for a power adapter /USB 2.0 connectivity cuts out the power adapter and nasty install
      Product Image
      You need extra storage and playback but can’t spare the space and weight. Not an issue, the new Extreme Slim External DVD-RW Drive offers reliable, full DVD read/write functionality that’s so thin at 14mm, it fits anywhere. With USB connectivity and no power adapter needed, it also works effortlessly every time, and looks truly chic in brushed metal and a slender square form that’s cool to carry.
      The easiest way to connect with instant plug and use on any PC.
      Works on every PC every time on the spot, no lengthy install or cumbersome drivers needed
      No dedicated power source needed, just connect to a USB port and start using right away
      Ultra slim low profile, easy to carry on the move
