Support
Having problem after you bought a product? You can find driver, manual download, and FAQ on ASUS Customer Service website. To provide you the best service ASUS provides you different ways to make a contact with us as well.
more
0
    SLIM EXT.DVD-RW Drive
    Product Image
    Read and Write on the Move
    • Compact, complete design guarantees excellent mobility with no compromise in performance
    • Smart flex USB cabling for mess-free, easy storage
    • Instant plug and play usability and USB-driven power leave out excess clutter and install hassles
      Product Image
      Created with practical daily usage in mind, the ASUS SLIM External DVD-RW Drive comes with simple features that make it a fantastic solution for storing, backing up and reading data. Lightweight, slim and install-free, it presents easy mobility and support for every optical media standard users need. No extra accessories or power supply needed!
      Ubiquitous USB 2.0
      The easiest way to connect with instant plug and use on any PC
      USB power
      No dedicated power source needed, just connect to a USB port and start using right away
      Wire manager
      Retractable wire design stores cables away out of sight for great looks and clutter control
      Plug and play
      Works on every PC every time on the spot, no lengthy install or cumbersome drivers needed
