Support
Having problem after you bought a product? You can find driver, manual download, and FAQ on ASUS Customer Service website. To provide you the best service ASUS provides you different ways to make a contact with us as well.
more
    ASUS PW100 Wireless Charging Stand
    Product Image
    Put Your Tablet at the Center of Your Life
    • Elegant Pyramid design with delicate texture and compact outlook
    • With Qi standard, compatible with most tablets or cellphones which also support Qi.
    • Wireless makes charging easy, built-in the status LED design
      Product Image
      With ASUS PW100, charging your tablet is no more a nightmare of struggling with clutters of connectors and cables. All you need to do is just put your tablet on PW100 and then it will charge your tablet automatically. With embedded status LED design, you can also know whether your tablet is charging or is full charged. In the aspect of hardware design, PW100 is designed based on the new wireless charging technology. With Qi standard compatible, PW100 is compatible with most tablets or cellphones which also support Qi standard in the market.
      pyramid_design
      pyramid_design Triangle shape stand
      Elegant Pyramid design with stable stand ability
      Qi Compatible Qi compatible
      Compatible with most tablets or cellphones which also support Qi
      Also can charge with cover on
      pyramid_design
      pyramid_design
      LED_charging Friendly LED charging notice
      Touch and Charge Wireless charging function
      Touch and Charge for free connection
      Never worry what type of plug for your device
      pyramid_design
