Silent Knight
    Silent Knight
    All Copper, Ultra Cooling for Dual-Core CPU
    CPU Support
    Intel® Core™2 Extreme/ Core™2 Duo/ Pentium® D (Dual-Core)
    Intel® Pentium® 4 HT/ Celeron® D CPU
    AMD Athlon™ 64 X2/ FX (Dual-Core)
    AMD Athlon™ 64/ Sempron™
    Fan Speed 2,200 rpm ± 10%
    Material Cu. Base + Cu. Punched Fins (128 fins) + 6 Heat Pipes
      Product Image
      Extremely Cool with Compact Size
      ASUS Features
      Excellent Performance for Overclockers
      100% copper materials ensure excellent heat dissipation for maximum cooling performance
      Quick
      Six copper heat pipes efficiently transfer heat to the fins, maintaining temperature for high-performance computing
      Universal Application
      The Silent Knight supports the Intel® Pentium® D Dual-Core CPU, Intel® Pentium® 4 LGA775 & Socket 478 CPU, AMD Athlon™ 64 X2 Dual-Core CPU, AMD Athlon™ 64(-FX) (939/940/AM2)
      Reliable
      The fan positioned inside the frame and VRM shield guides cool air to critical components around the CPU for stable operation
      Easy Installation
      The patented retention module enables easy installation in three simple steps even without removing the motherboard from the system or memory modules form the board and regardless of the processor platform.
      Cooling Chart
