Triton 79 AMAzing
    Product Image
    12cm fan design for amazing cooling
    - Over-clocking for Quad-core CPU support
    - Peaceful computing environment at 18dBA
    - Decorate your PC with luxury design
      12cm fan design for AMAzing cooling
      Deluxe limited-edition package with ultra-exclusive identification card
      The Triton 79 AMAzing reaches the flagship in highest performance, stylish outlook and gorgeous package. For this deluxe limited-edition package, every component is well protected by Polyurethane foam plastic. Every owner of Triton 79 AMAzing has the ultra-exclusive identification card typed with limited-edition serial number.
      Over-clocking for Quad-Core CPU support
      The Triton 79 AMAzing is able to support the Intel® Core™2 Extreme / Core™2 Quad Quad-Core CPU (LGA775) and AMD Athlon™64 FX/X2 Dual-Core processors (939/940/AM2/AM2+/1207+). With support for so many different processors, the Triton 79 AMAzing is ideal for gamers who wish to overclock their systems and use multiple computing platforms.
      Superior cooling performance and peaceful computing environment at 18dBA
      The Triton 79 AMAzing incorporating nickel-plating copper base,4 copper heat pipes, aluminum fins and PWM function 12cm fan controls processor temperature at levels most suitable for highest-performance and most stable computing environment at a mere 18dBA.
      The luxury design of the cover and the whole nickel-plating make a stylish system interior.
      The gorgeous limited-edition package
      Unique golden accessories
