Pro A320M-R WI-FI
    Pro A320M-R WI-FI
    AMD Micro-ATX A320 business motherboard with USB 3.1 Gen 2 type C, WiFi, plus enhanced security, reliability and manageability for TCO reduction
    • ASUS-exclusive self-recovering BIOS technology for automatic system BIOS recovery from a verified backup
    • ASUS LPC debug header for more efficient troubleshooting
    • Event log for capturing and managing detailed system information
    • Innovative moisture-resistant coating to protect the motherboard from harsh environments
    • Commercial BIOS kit to make customization faster and more efficient
      Product Image
      ASUS Pro business motherboards provide enhanced features to smooth your IT operations, including comprehensive system protection, 24/7 stability and reliability and an improved management suite for easier customization. Known as the world's biggest and best-known motherboard brand, ASUS provides world-class after-sales service and guaranteed long-term availability to maximize your investment over the product life cycle and offers a high-quality, TCO-optimized solution for your business computing-needs.
      1 D-Sub
      2 HDMI
      3 DisplayPort
      4 USB 3.1Gen 1 Ports
      5 LAN
      6 USB 3.1Gen 1 Ports
      7 1 x 1 Dual Band
      Wi-Fi + BT 5.0
      8 Audio
      9 LPC Debug header
      10 1 x USB 3.1 gen2 Type C
      11 DDR4 Support
      AMD Ryzen™ Processors
      2 x DIMM, Max. 32GB, DDR4 2933*/2666/
      2400/2133 MHz ECC and non-ECC, Un-buffered Memory
      AMD 7th Generation A-series/Athlon™ Processors
      2 x DIMM, Max. 32GB, DDR4 2400/2133 MHz
      Non-ECC, Un-buffered Memory
      12 AMD AM4 Socket
      13 SPI TPM header
      14 PCIe 3.0/2.0 x16
      15 AMD A320
      16 PCIe 3.0/2.0 x1 slot
      17 4 x SATA 6Gb/s Ports
      Internationally Certified Business Motherboard
      ASUS business motherboards are enterprise proven with leading quality that exceeds industry standards. Certified by multiple international safety and environmental organizations, ASUS business motherboards provide a safe, secure and sustainable solution, making them the ideal choice for your business.
      ASUS Shield
      Enhances system security from bottom to top
      ASUS Self-recovering BIOS
      ASUS-exclusive BIOS protection technology automatically recovers the system BIOS with a verified backup in the event of an update failure, preventing the need to replace or reinstall hardware.
      LEARN MORE
      ASUS Secure Boot
      ASUS business motherboard is set to check the firmware and signature of each piece of boot software.
      Trusted Platform Module (TPM)
      Hardware-based security offers better data protection, enhances network security, protects digital identities and ensures platform integrity.
      Certified NIST SP 800-147
      ASUS business motherboard is certified by the national computer security standards.
      With ASUS Self-recovering BIOS
      The user simply needs one step to restore the latest BIOS update.
      • Benefits
      • Ensures safe BIOS updates
      • Reduces maintenance frequency and costs
      • Requires no extra software
      • Provides automatic update failure detection and recovery
      Standard process for BIOS update crash recovery
      The user needs four steps to reinstall the BIOS update:
      CLOSE
      ASUS Reliant
      Ensures consistent performance with the finest components and rigorous reliability testing
      USB 3.1 Gen 2 Type-C
      Ultrafast 10Gbps data-transfer speeds with USB 3.1 Gen 2
      Onboard USB 3.1 Gen 2 Type-C™ ports provide ultimate connection flexibility, ultrafast data-transfer speeds of up to 10Gbps and convenient, reversible connectivity.
      802.11ac Wi-Fi
      Fastest onboard Wi-Fi up to 433.3Mbps
      Pro A320M-R Wi-Fi has 802.11ac Wi-Fi with 1x1 2.4/5GHz antennas for up to 433.3Mbps* transfer speeds to ensure that every connected user experiences the best wireless and online speeds!
      *Actual speed varies, and depends on networking conditions.
      ASUS Trouble Shooting Solution
      ASUS Debug header is a 10-1 pin low pin count (LPC) header for connecting to debug cards for faster, more efficient motherboard troubleshooting. When connected to an ASUS Debug Card, administrators can view error and debugging codes on the integrated LCD display, and get better idea of initialization and recovery processes. ASUS business motherboards provide a complete troubleshooting solution, making mass production faster and more cost effective.
      * Please contact your local sales representative for debug card information.
      24/7 Reliability Test
      Optimized for twenty-four seven operations, the motherboard is tested under temperature up to 45°C and relative humidity up to 80% to ensure it can handle diverse temperature and humidity range of different location.
      Anti-moisture Coating
      Protection against moisture and corrosion
      An innovative moisture-resistant coating protects the motherboard in humid environments, such as factories, libraries, data centers and internet cafes. It also minimizes internal corrosion by preventing adhesion and migration of moisture, prolonging the life of the motherboard.
      Anti-sulfur Resistors
      Consider long-term reliability of commercial product, ASUS business motherboard is equipped with anti-sulfur resistors. The resistors provide excellent resistance to sulfuration by constructed in a high grade ceramic body (aluminum oxide). With anti-sulfur resistors, ASUS business motherboard can be operated under the harsh environments.
      LANGuard
      Pumped-up throughput. 2.5X higher surge tolerance.
      ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors ensuring a more reliable connection and better throughput, plus electrostatically guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
      Overvoltage Protection
      World-class circuit-protecting power design
      An exclusive circuit design with built-in voltage regulators to protect your chipset, connectivity ports, and audio codecs from damage caused by unexpected high-level voltages from unstable or inferior power supplies.
      Stainless-Steel Back I/O
      3X corrosion-resistance for greater durability
      Corrosion-resistant stainless steel back I/O panels bonded with chromium oxide have a lifespan that's three times longer than ordinary panels.
      ESD Guards
      Electrostatic discharge protection
      ASUS ESD Guards prevent damage from electrostatic discharge, up to +/- 10kV for air discharge and +/-15kV for contact discharge, arranged in an active-protective-circuit design that prolongs the life of components.
      ASUS Management Suite
      Makes customization and management more efficient
      Event Log
      A built-in event log enables easier troubleshooting by capturing useful system information
      • BIOS updates
        Update status, latest version and update time
      • AC power loss
        Abnormal power loss events
      • RTC reset
        Time of real-time-clock (RTC) reset
      • Chassis intrusion
        Record of when chassis is opened
      • Hardware changes
        Modifications to CPU, memory or HDDs
      • Hardware status
        USB over current, CPU over temperature, and CPU over voltage events
      ASUS Commercial BIOS Kit
      ASUS understands how important a customized product impacts users' mind share, experience the brand new Commercial BIOS Kit for partial BIOS update solution!
      • BIOS Value Edit Tool
        Customize the BIOS options
      • BIOS Boot Logo Tool
        Brand your builds with a customized boot logo
      • OEM Activation (OA) Tools
        Add or remove the OEM Activation key
      • Desktop Management Interface (DMI)
        Easily add customer information, such as company name, to the BIOS
      • Intel® Management Engine (Intel® ME) Driver
        Update the Management Engine without flashing the whole BIOS
      Easy Assembly
      Box Headers
      All USB 3.1 Gen 1 and 2.0 headers are box style, enabling fast connector installation and preventing pin damage.
      Fixed-position Connectors
      Connector positions on ASUS business motherboards remain consistent across product generations, protecting training, manufacturing and investments in supporting hardware.
      Color-coded Connectors
      Color-coded connectors enable easy identification and cable-matching, speeding up the production line. investments in supporting hardware.
      AMD CPU and chipset features
      AMD A320 Chipset
      The AMD A320 chipset delivers outstanding overclocking capabilities for the latest AMD® AM4-socket Ryzen™ processors, 7th Generation A-series APUs and Athlon™ CPUs. It provides two USB 3.0 ports, and four 6Gbps SATA ports for faster data retrieval.
      AM4 socket for 3rd/2nd/1st Gen AMD Ryzen™ / 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics / Athlon™ with Radeon™ Vega Graphics / 7th Generation A-Series / Athlon X4 Processors
      This motherboard supports AMD® Ryzen™ processors, 7th Generation A-series accelerated processing units (APUs) and Athlon™ CPUs. The high-performance Ryzen™ processor supports up to eight cores, and is based on the innovative Zen core architecture . The 7th Generation A-series APUs feature integrated AMD Radeon R-series graphics. AMD AM4-socket processors feature dual-channel DDR4 memory, native 5Gbps USB 3.0 and 16 PCI Express® 3.0/2.0 lanes for superb performance.
      • PRO A320M-R Wi-Fi
      • ASUS Shield
      • ASUS Reliant
      • ASUS Management Suite
      • Easy Assembly
