DUAL-RTX2070S-A8G-EVO
    The ASUS Dual GeForceR RTX 2070 SUPER? EVO Advanced edition 8GB GDDR6 with two powerful Axial-tech fans for high refresh rate AAA gaming and VR
    • RT Cores: Dedicated ray tracing hardware enables fast real-time ray tracing of objects and environments with physically accurate shadows, reflections, refractions, and global illumination.
    • Concurrent Floating Point and Integer Processing: Turing GPUs more efficiently process the compute heavy workloads of modern games.
    • Ultra-fast GDDR6: Experience up to 496 GB/s of memory bandwidth for high-speed, high-resolution gaming.
    • Axial-tech fan design features a smaller fan hub that facilitates longer blades and a barrier ring that increases downward air pressure.
    • 0dB Technology lets you enjoy light gaming in relative silence.
    • 2.7-slot Design expands cooling surface area to make the most of the two powerful Axial-tech fans.
    • Auto-Extreme Technology uses automation to enhance reliability.
    • A Protective backplate secures components during transportation and installation.
    • GPU Tweak II provides intuitive performance tweaking, thermal controls, and system monitoring.
    • 144-hour Validation Program puts cards through a series of stringent tests to ensure compatibility with the latest games.
    Product Image
    Cooling
    Engineering
    Software
    Experience
    0%
