Portable Friction Mount
    A great match for your car
    • Vehicle dash mount for use on any stable surface
    • Securely holds your navigation smartphone in vehicle
    • Does not slide or detach while vehicle is in motion
    • Adjustable to position your navigation smartphone in a variety of angles
      Stability and mobility all in one! Our portable friction mount secures to your dashboard with a non-skid bottom, and the pliable base molds to fit any dash. Traveling? Fold down the integrated arm for storage, and easily move the mount from vehicle to vehicle.
