Filter results: 251 Devices
Sort by:
Recommend
Newest
Most Popular
Ratings
Sort Filter
Clear all
By Product
Series
Cancel
Apply
Back to filter
NEW
ROG BP1800 Gaming Backpack
0.0 out of 5 stars.
The ROG BP1800 Gaming Backpack has a 24-liter internal volume and includes a padded compartment to protect up to an 18-inch laptop. It features ample storage for everyday essentials and other gear, and includes a breathable mesh backrest to keep you cool in all weather conditions.
NEW
ROG Pelta
0.0 out of 5 stars.
Tri-mode RGB gaming headset with ROG SpeedNova wireless technology, 50 mm ROG titanium-plated diaphragm drivers, refined wireless sound signature, 10 mm super-wideband boom microphone, lightweight 309-g design, plus ASUS Aura Sync RGB lighting
NEW
ROG Strix Scope II 96 RX Wireless
0.0 out of 5 stars.
ROG Strix Scope II 96 RX Wireless optical gaming keyboard with tri-mode connection, streaming hotkeys, multi-function controls, ROG RX Optical Switches, ROG keyboard stabilizers, PBT doubleshot keycaps, silicone dampening foam, additional ROG-themed ABS keycaps, three tilt angles, and wrist rest.
NEW
ROG Falchion Ace HFX
0.0 out of 5 stars.
ROG Falchion Ace HFX 65% analog gaming keyboard with pre-lubed ROG HFX Magnetic Switches, Rapid Trigger toggle, Speed Tap Mode, interactive touch panel, 8000 Hz polling rate, five-layer dampening and silicone gasket mount, dual Type-C ports, three tilt angles, and cover case
NEW
ROG Harpe Ace Mini
0.0 out of 5 stars.
The ROG Harpe Ace Mini is an ultralight 49-gram semi-symmetrical gaming mouse with a shape approved by pro FPS players. Equipped with 42,000-dpi ROG AimPoint Pro optical sensor and ROG Optical Micro Switches, the ROG Harpe Ace Mini displays industry-leading wireless performance with SpeedNova wireless technology and supports up to 8,000 Hz wireless polling rate (compatible with the ROG Polling Rate Booster).
NEW
ROG Archer Tech Pouch BC1003
0.0 out of 5 stars.
All your gear, ready to go
NEW
ROG Archer Carry Bag BC1004
0.0 out of 5 stars.
Everyday Durability, Ultimate Convenience
NEW
ROG Azoth Extreme
0.0 out of 5 stars.
ROG Azoth Extreme 75% gaming custom keyboard featuring a full aluminum alloy chassis, carbon fiber positioning plate, adjustable gasket mount, full-color OLED touchscreen with three-way control knob, extended wrist rest, magnetic feet, tri-mode connectivity with 2.4 GHz SpeedNova technology, hot-swappable pre-lubed ROG NX mechanical switches, and Mac support
NEW
ROG Delta II
0.0 out of 5 stars.
Tri-mode wireless gaming headset with ROG SpeedNova, 50 mm titanium-plated diaphragm drivers, and refined wireless sound signature, 10 mm super-wideband boom microphone, DualFlow Audio, up to 110-hour battery life, lightweight 318-g design, plus ASUS Aura Sync RGB lighting
NEW
ROG Harpe Ace Extreme
0.0 out of 5 stars.
The ROG Harpe Ace Extreme is a high-end, 47-gram wireless gaming mouse made out of carbon fiber composite, is equipped with 42,000-dpi ROG AimPoint Pro Optical Sensor and ROG Optical Micro Switches, and also comes with glass mouse feet and 8,000 Hz ROG Polling Rate Booster.
NEW
0.0 out of 5 stars.
Experience supersmooth cursor control with the ROG Polling Rate Booster – a new ROG-exclusive accessory that offers up to true 8000 Hz wireless polling rates when used with compatible ROG mice and keyboards.
NEW
ROG Dye-Sub PBT Keycaps
0.0 out of 5 stars.
ROG Dye-Sub PBT Keycaps for ROG NX switches are made of premium, durable PBT and feature dye-sublimated legends and stylish ROG elements.
NEW
ROG Archer ErgoAir Gaming Backpack BP3800
0.0 out of 5 stars.
Elevate your adventure.
NEW
ASUS SmartO Mouse MD200 Silent Plus
85g
0.0 out of 5 stars.
Work faster and smarter with the new ASUS SmartO Mouse Silent Plus. Its meticulously crafted low-profile silhouette is ergonomically designed for comfortable all-day use. A high-performance sensor ensures precise tracking on almost any surface, while a special switch design ensures almost-silent mouse clicks. Plus, an elastic loop provides convenient portability. ASUS SmartO Mouse Silent Plus has a new Green Tea Latte finish and includes Armoury Crate software for more customization options to give you unmatched style and functionality.
NEW
ROG Cetra True Wireless SpeedNova
0.0 out of 5 stars.
Bluetooth® and 2.4 GHz wireless gaming headphones with ROG SpeedNova wireless technology, 24-bit 96 kHz audio and Dirac Opteo™, Bone-Conduction AI Microphones, Adaptive ANC with Auto mode, up to 46-hour battery life, Hybrid Multipoint, plus ASUS Aura RGB lighting support
ASUS Marshmallow Mouse MD100 Lite
0.0 out of 5 stars.
ASUS Marshmallow Mouse MD100 Lite adds a handy strap that makes it easy to carry around. To keep things moving, this energy-efficient mouse lasts up to a year on a single AA battery, and it features switches with a 10-million-click lifespan. A quick press of a button allows you to switch between three DPI levels, and 100% PTFE mouse feet provide a smooth glide on any flat surface.
ROG Ranger Gaming Backpack 16
0.0 out of 5 stars.
Pack smart, play with style
ASUS Fragrance Mouse MD101
0.0 out of 5 stars.
ASUS Fragrance Mouse - Seamless performance, scented sophistication
ROG Keris II Ace
0.0 out of 5 stars.
The ROG Keris II Ace is an ultralight 54-gram ergonomic gaming mouse with a shape tested by pro FPS players. Equipped with 42,000-dpi ROG AimPoint Pro optical sensor, ROG Optical Micro Switches and the ROG SpeedNova wireless technology, the Keris II Ace is also able to enhance gaming performance even further with the ROG Polling Rate Booster, which supports polling rates up to 4,000 Hz in wireless mode and up to 8,000 Hz in wired mode.
ROG Falchion RX Low Profile
0.0 out of 5 stars.
ROG Falchion RX Low Profile 65% compact wireless gaming keyboard with ROG RX low-profile optical switches, tri-mode connection with ROG SpeedNova wireless technology and Omni Receiver, protective cover, integrated silicone dampening foam, interactive touch panel, and MacOS support
comparison icon
Compare (0)
