ASUS ZenWiFi ET8
ASUS ZenWiFi
Level Up Your Mesh
WiFi 6E: The Future of WiFi
ASUS stands at the forefront of networking technology, and always brings you the very latest WiFi standards. ASUS ZenWiFi ET8 features the latest WiFi 6E, an expanded version of WiFi 6 that adds a new 6 GHz frequency band, giving better connectivity and lower latency than previous generations.*
* WiFi 6E requires WiFi 6E-compatible devices to enjoy all benefits.
Wifi 6E mesh
New 6 GHz Band for Stable Backhaul
5 GHz and 2.4 GHz bands are getting more and more crowded with the growing number of home devices. The new 6 GHz band is reserved exclusively for WiFi 6E devices, so there's no interference from other legacy devices. This makes it ideal for use as a stable backhaul connection.*
*5 GHz backhaul can also be used, but we recommend using 6 GHz.
Learn more about backhaul and WiFi 6E
6 GHz backhaul 6 GHz backhaul
Smart & Flexible Backhaul Configuration
ASUS ZenWiFi ET8 gives you flexible backhaul options: 6 GHz or 5GHz wireless, and Ethernet. The router intelligently chooses the most reliable method for you, based on connection quality. If you prefer, you can also manually choose the type of backhaul connection.
WiFi 6E Boosts Maximum Capacity
WiFi 6E provides seven extra 160 MHz channels to meet the growing needs of home devices.* There's no need for DFS on 6 GHz band, so your WiFi 6E devices can enjoy immediate zero-wait connections. ZenWiFi ET8 is also fully compatible with all your existing WiFi devices, so you can use it right now.
*Subject to regulatory limitations, and co-existence with 5 GHz WiFi. Number of channels may be less than seven.
ZenWiFi ET8 speed
WiFi 6E
Put Your WiFi into Top Gear!
With a total bandwidth of up to of 6600 Mbps, ZenWiFi ET8 is up to 2.2X faster* than tri-band AC3000 (WiFi 5) routers **.
* Compatible WiFi 6E device required.
** The data compares speed of 4x4 WiFi 6E on 6GHz 160 MHz bandwidth with 1024QAM modulation to speed of 4x4 11ac on 5 GHz 80 MHz with 256QAM modulation.
Whole-home Coverage
ZenWiFi ET8 coverage ZenWiFi ET8 coverage
The ZenWiFi ET8 system consists of a pair of ASUS AXE6600 WiFi 6E routers, featuring unique technologies that give you superfast, reliable and secure WiFi connections — inside or outside your home!
5500 sq.ft.
6+ rooms
2750 sq.ft.
4+ rooms
Learn more about whole-home mesh ZenWiFi
5500 sq.ft.
6+ rooms
2750 sq.ft.
4+ rooms
Instant Guard Makes Public WiFi Secure
ASUS Instant Guard uses the power of your ZenWiFi ET8 to add rock-solid VPN security to any public WiFi connections you use. It helps protect your private information such as credit card details, business data, emails and more.
Learn more about secure public WiFi
Download ASUS Instant Guard app
Flexible Network Naming
Uniquely, ZenWiFi lets you choose how you name your WiFi networks: a single name for everything, or separate names for each frequency band. The choice is yours!
Easier-than-ever Setup
3-step setup with the ASUS Router app
ZenWiFi ET8 setup
ZenWiFi ET8 setup
ZenWiFi ET8 setup
1
Turn on ASUS ZenWiFi ET8
2
Create a WiFi network name and an admin account
3
Wait for several minutes, and you're done!
What makes ASUS ZenWiFi so easy to set up?
  • Auto synchronization: One-time setup, with auto synchronization for every hub in the package.
  • Auto identifying: each unit can work as the main router or as a node. ZenWiFi identifies the main router by detecting its WAN connection, so you don't have to tell it.
  • Auto backhaul selection: Intelligently picks the best backhaul connection for your environment.
Make the Internet a
Safer Place for Everyone
AiProtection Pro with Advanced Parental Controls is free for life. It gives you total peace of mind, and you can keep an eye on everything that's happening on your network via the mobile app.
Commercial Grade Security
Learn more about network security
No Subscription Fee
Some routers only offer 3 years of protection, ASUS AiProtection has you covered for the life of your product.
Protection Against Attacks
Intrusion Prevention System (IPS) blocks all common internet-based attacks.
Block Access to Malicious Websites
AiProtection uses Trend Micro's official database to identify and block known malicious sites, preventing infection even before you click.
Infection Detection and Blocking
Even if an already-infected device is connected to ZenWiFi, AiProtection prevents any personal data on the device from being compromised.
More Stable WiFi with Wired Connections between ZenWiFi Hubs
If you have Ethernet ports in your walls, you can set ZenWiFi AX Mini to use Ethernet backhaul, reserving all WiFi bands for your wireless devices for even more stable and reliable networking.
AiProtection has everything you need in one place: it's super-easy to view or change security settings on each of your family member's devices, so your kids can be safer when surfing!
Internet Activity Dashboard
View each family member's internet activity on a clear graphical dashboard showing the peak time and what kind of content they are viewing. You can group devices that belong to your children to view aggregated data and apply scheduled block times and content filters with just a few taps.
Easy Child-Safe Protection
Choose the preset that matches the age range of your family members, and it will suggest internet access time schedules and content filters for all their devices.
Schedule Block Time
Reserve valuable family time or help your children develop responsible behavior by selecting scheduled time periods to block internet access on specific devices.
Content Filter
Block specific categories of mobile apps and websites, and apply these settings to all devices belonging to individual family members. The advances filtering integrates Trend Micro’s Deep Packet Inspection (DPI) engine to filter not only by website URL, but also by the internet packets themselves, which means it filters content viewed not only in a web browser, but also within mobile apps on your devices.
Schedule Block Time
Content Filter
Smart Looks for Smart Homes
ASUS ZenWiFi ET8 works words perfectly with smart-home services- including Alexa skills.
Read more
AiMesh Technology
Easy setup. Flexible management.
You can mix different AiMesh-compatible routers, and add new ones at any time to improve coverage. Even non-experts can quickly set up AiMesh technology, while more experienced users will appreciate the comprehensive advanced networking features.
How do I expand my network?
Flexible and Scalable Wireless Networking
If you need more coverage or new functions, you can simply add another compatible router to your AiMesh network at any time!
Learn more about AiMesh
Related products
previous image
next image
  • Actual data throughput and WiFi coverage will vary from network conditions and environmental factors, including the volume of network traffic, building material and construction, and network overhead, result in lower actual data throughput and wireless coverage.
  • Quoted network speeds and bandwidth based on current IEEE 802.11ac specifications. Actual performance may be affected by network and service provider factors, interface type, and other conditions. Connected devices must be 802.11ac-compatible for best results.
  • WPA/WPA2 enterprise is only available on single router, is not available under AiMesh mode.
  • When traditional QoS is enabled, there will be limitations due to the actual Internet service bandwidth and different environment, and there may be a risk of speed reduction.
  • Due to the different power supply requirements on USB external hard disk and 4G/5G Modem device, to ensure that the external device can be used stably, if the USB external device exceeds the standard USB 2.0 (5V/500mA) and USB 3.1 Gen 1 (5V/900mA) power supply requirements, you need to use it with an independent external power supply.
  • If you use the product in conjunction with a third party service, you are responsible for complying with the third party provider's terms and conditions and privacy policy and are also at the risk of such use. ASUS does not provide support or guarantee continuous integration support for products that are not part of ASUS.
  • The device is restricted to indoor use only when operating in the 5150-5350 MHz frequency band in certain regions, including the EU, Asia-Pacific countries, Australia, and Canada. Outdoor use in this band may be prohibited or require regulatory approval. Check local regulations before deployment.
  • For models with Time machine support, starting with macOS 26 (Tahoe), Time Machine no longer supports creating new backups on USB-connected storage devices. Existing Time Machine drives that were previously configured remain compatible and can continue to be used for backup and restoration.
