- Crafted with CNC machining precision, Ceraluminum™ top cover: nature-inspired hues, wear resistance, scratch resistance, easy to clean.
- Dual-mode wireless connectivity with Bluetooth® and 2.4 GHz enables pairing with up to four devices. Track-on-Glass sensor ensures smooth, accurate control across almost any surface, including glass.
- Support Type-C fast charging with customizable DPI (800 to 4200 DPI), shortcut assignment, and low battery alert.
ROG Strix Morph 96 Wireless custom gaming keyboard with hot-swappable ROG NX V2 mechanical switches, south-facing PCB, tri-mode connectivity, ROG SpeedNova wireless technology, gasket mount and dampening layers, three adjustable tilt angles, durable ROG doubleshot ABS keycaps, and MacOS support
ROG Kithara gaming headset with ROG-Tuned 100mm HIFIMAN planar magnetic drivers, open-back architecture, full-band MEMS boom microphone, dual 3.5mm input, 4.4mm balanced, 3.5mm, 6.3mm single-ended plugs
The ROG Throne II Core Gaming Headset Stand for ROG gaming headsets, featuring signature ROG text patterns, silver-foil ROG logo, solid aluminum-alloy frame, and anti-slip base for premium aesthetics and stability
ROG Azoth 96 HE Lite analog gaming keyboard with hot-swappable ROG HFX V2 magnetic switches and ROG Hall Sensor; featuring an OLED display, three-way knob, tri-mode connectivity with ROG SpeedNova 8K wireless technology, Zone mode, six-layer dampening and detachable silicone wrist rests
ProArt Mouse MD301 boasts an ergonomic design and features swappable left and right buttons that support both micro and optical switches, allowing you to personalize click feel and extend the lifespan of the mouse. The SmartShift Wheel enables quick navigation through long pages, enhancing productivity. It also offers six programmable buttons, a high-performance 8000 dpi sensor for precise tracking, and tri-mode USB, 2.4 GHz RF, and Bluetooth® connectivity to support up to five devices.
ProArt Keyboard KD300 is a 26.8 mm-slim, 65% low-profile keyboard with navigation keys and a premium aluminum top cover. This versatile keyboard features tri-mode connectivity to support up to five devices simultaneously via 2.4 GHz wireless, Bluetooth® and USB. For convenience, ProArt Keyboard KD300 has a PC/Mac toggle switch, a storage slot for its magnetic dongle, and an innovative touch panel for intuitive control of volume, media playback and lighting. Meanwhile, the web-based ASUS Gear Link interface allows you to customize profiles, key mappings, macros and lighting to personalize the keyboard for your creative workflows. ASUS RX Red Low-Profile optical switches deliver smooth, fast, and precise keystrokes, while two adjustable keyboard tilt angles ensure an ergonomic typing position.
ROG Ergo Monitor Arm AAS01R – Mechanical Spring Monitor Mount with Desk Clamp and Grommet Mount, Holds Up to 49-inch* within 13.5kg, Pivot/Swivel/Tilt/Rotation/Height Adjustable, Double-sided Cable Management, VESA 100 x 100 mm
Tri-mode wireless gaming headset with ROG SpeedNova, 50 mm titanium-plated diaphragm drivers, and refined wireless sound signature, 10 mm super-wideband boom microphone, DualFlow Audio, up to 110-hour battery life, lightweight 318-g design, plus ASUS Aura Sync RGB lighting
The ROG Scabbard II XXL-KJP is a large gaming mouse pad with a water-, oil-and dust-repellent surface and anti-fray, flat-stitched edges, plus a nonslip rubber base
The ROG Keris II Origin-KJP is a 63-gram ergonomic gaming mouse with a shape tested by pro FPS players. The mouse features vibrant 3-zone RGB lighting and is equipped with the 42,000dpi ROG AimPoint Pro optical sensor, ROG Micro Switches II, and ROG SpeedNova wireless technology. The Keris II Origin-KJP is also compatible with the ROG Polling Rate Booster, which supports a wireless 8000Hz polling rate.
ROG Falchion Ace 75 HE gaming keyboard with hot-swappable ROG HFX V2 & V2X Magnetic Switches, ROG Hall Sensor, Rapid Trigger toggle, sensitivity adjustment wheel, interactive touch panel, 8000 Hz polling rate, six-layer dampening, three adjustable tilt angles, durable ROG doubleshot PBT keycaps, and protective carry case
ProArt CaliContrO MCA02 3-in-1 Colorimeter – Professional Color Measurement, Hardware / Software Calibration, Display OSD Control, ASUS Dial, Compatible with Adobe Software
The ASUS Jelly75 is a wireless mechanical keyboard featuring a striking Orange Meadow/Volt Green color scheme. Its gasket-mounted compact design delivers a quiet, comfortable typing experience with dampened vibrations. The soft white backlight enhances visibility while reducing eye strain. With plug-and-play wireless connectivity, broad Windows/macOS compatibility, and distinctive contrast-key accents, this keyboard blends style with functionality for work or play.
