HYPER M.2 X16 CARD
    HYPER M.2 X16 CARD
    Upgrade your RAID
    • Supports up to four PCIE® 3.0 M.2 drives, with transfer bandwidth up to 128Gbps
    • Supports Intel VROC technology, allowing you to use CPU PCIe® lanes to create BOOTable RAID arrays
    • Integrated blower-style fan to prevent throttling
      Product Image
      Upgrade your RAID
      With Intel® Virtual RAID on CPU (VROC), unused CPU PCle® lanes can be assigned to storage, allowing you to create a bootable RAID array with multiple M.2 SSDs. Unlike motherboard PCH-based RAID, VROC isn't confined by the 32 Gbps DMI bottleneck, so multiple drives can be teamed to provide incredible throughput.
      One card,
      4X the bandwidth
      Hyper M.2 x16 Card is designed specifically for VROC and features four M.2 slots, providing up to 128 Gbps of bandwidth per card.
      Design for unthrottled transfer speed
      The card is armed with a large heatsink and active fan to ensure drives are kept cool. An insane number of drives can run in parallel across multiple VROC cards to deliver staggering throughput and massive capacity for system drives, scratch disks, and anything else you want to access at warp speed.
      Back to top
