ROG Addressable LED Strip
    ROG Addressable LED Strip with magnetic backing and Aura Sync RGB - 30 & 60cm
    • High-brightness addressable RGB strip with individually programmable LEDs
    • Magnetic backing for easy attachment to metal surface, and a 3M™ DIY kit with double-sided tape for other surfaces
    • Synchronize lighting with Aura Sync gear via 3-pin addressable RGB headers on motherboards for infinite lighting possibilities
      Product Image
      ROG Addressable LED Strip puts bright illumination exactly where you want it, with individually controllable lights for the ultimate personalized immersion. Available in 30cm and 60cm lengths, our Addressable LED Strip has integrated magnets for quick placement and is easily daisy-chained — enabling custom lightshows to extend as far as your ambition.
      Connect, attach, shine
      ROG Addressable LED Strip has built-in magnets for fast, firm attachment to metal surfaces, and comes with strong 3M adhesives for a firm grip anywhere. Our Addressable LED Strip is chainable, so it’s a cinch to connect multiple strips in series.
      Infinite lighting possibilities
      ROG Addressable LED Strip is part of the flourishing ASUS Aura Sync ecosystem, ready fit right into an existing setup to up the illumination ante. Attach it where you need and then let your creativity shine, with the help of the intuitive Aura app and its selection of fascinating lighting effects.* You can also synchronize easily with other Aura Sync-compatible gear for harmonious aesthetics and stunning PC illumination, so set your imagination free!
      *Motherboards with onboard addressable header required. Visit the ASUS Aura microsite to learn more.
      **effects various by models.
      ***Cutting ROG Addressable LED Strip voids the warranty.
