USB 3.1 TYPE-C CARD
    USB 3.1 TYPE-C CARD
    World's first and fastest USB 3.1 Type-C PCIe card
    • 10Gbit/s data-transfer speeds – twice as fast as USB 3.0
    • Future-proof reversible Type-C connector
    • Fits in any PCIe x4, x8, x16 slot
    • Even faster USB 3.1 transfers with included ASUS USB 3.1 Boost utility
      Product Image
      World's first easy-fit 10Gb/s USB 3.1 card!
      ASUS brings you the world's first discrete USB 3.1 card with a reversible Type-C socket for any-way-up connections. ASUS USB 3.1 Type-C Card (Single) is the simple-to-fit PCI Express expansion card that works with any PCIe x4, x8 and x16 slot. It adds the all-new reversible USB 3.1 Type-C port to your ASUS motherboard* for brilliant simplicity and ultimate-speed transfers of up to 10Gb/s — or twice as fast USB 3.0. The next-generation standard is completely backward-compatible with your existing gear, and you'll be all set for USB 3.1's breakneck speeds. And ASUS-exclusive USB 3.1 Boost technology pushes real-world speeds faster than ever before, sequential read/write speeds of up to 854.6/863.9MB/s.
      Intel core™ I7-5930K @ 3.5GHz CPU
      ASUS X99-PRO motherboard (BIOS 0201)
      ASUS USB 3.1 Type-A Card
      SK Hynix MEN-HYN DDR4-2133 4G x2 memory
      Win8.1 64bit | Samsung 840 EVO 250GB x2
      Learn more about ASUS USB 3.1 complete solution
      2-step Installation to ensure the best USB 3.1 performance
      Visit your ASUS motherboard's support page to download and refresh the latest BIOS.
      Tip – use USB BIOS Flashback* to flash the BIOS using a USB storage device.
      (USB BIOS Flashback is available on selected models)
      Install the ASUS USB 3.1 Card driver from support DVD or ASUS support site.
