ASUS USB-C Cable
ASUS USB-C Cable
Handy USB-C cable for data transfer and charging
- Easy charging for any USB-C™ device
- Enjoy smooth USB 2.0 data connections
- Convenient 0.9m length, torture-tested for durability
Compare
view on your table
View the model in 3D
With the ASUS USB-C ™ Cable you can easily charge your USB-C ™ devices, or transfer your photos and data at smooth USB 2.0 speeds. Torture-tested for toughness and durability, the ASUS USB-C ™ Cable is built to survive the rigors of everyday use.
Torture-tested
Life test
10,000
times
Tensile resistance
40N
Bending Strength
3000
times
Related products
Compare (0)
