• Features
  • Tech Specs
  • Gallery
  • Support
ROG Phone 30W Adapter & USB-C Cable
Fast Charging For Your ROG Phone
  • Supports Quick Charge 4.0 and Power Delivery 3.0
  • Delivers more power for shorter, safer charge times, and also stays cooler when it’s charging.
With support for Quick Charge 4.0 and USB Power Delivery, the ROG Phone 30W Adapter and USB-C™ Cable is the perfect accessory for charging your ROG Phone in the shortest possible time!
Safe and Cool
The ROG Phone 30W Adapter & USB-C Cable uses direct-charge technology that puts the charging circuitry inside the power adapter rather than the phone. This delivers more power for shorter, safer charge times, and also means your ROG Phone stays cooler when it’s charging.
Rigorously Tested to Ensure Top Quality
Fully torture-tested for toughness, durability and safety , the ROG Phone 30W Adapter & USB-C Cable also meets DOE Level VI and ErP Tier 2 power-efficiency standards.
Adapter life test Cable life test Tensile resistance Bending strength
150,000 10,000 40N 3000
hours* times*   times
Exclusive ASUS PowerSafe Protection
With Over Temperature Protection, Short Circuit Protection, Over Voltage Protection, Over Current Protection, Drop Test and Power saving, , the ROG Phone 30W Adapter & USB-C Cable is built to survive the rigors of everyday use.
Over temperature protection Short circuit protection Over-voltage protection Over-current protection Power saving
CUSTOMER REVIEWS
Product Comparison
Product added to comparison. Add up to 4 products or proceed to view compare products selected.
    VIEW COMPARISON
    ROG Footer
