https://techinstyle.asus.com/hub/mobile/
    ZenFone Max Pro (M2) Clear Soft Bumper (ZB631KL)
    Transparent Beauty
    • Perfectly designed protection for your ZenFone Max Pro (M2)
    • Prevents scratches to preserves the beauty of ZenFone Max Pro (M2) and keep it in pristine condition
    • Comfortable to hold, made from elegant transparent material that shows off the full beauty of your ZenFone Max Pro (M2)
      Product Image
      ZenFone Max Pro (M1) Folio Cover
      ZenFone Max Pro (M2) Clear Soft Bumper is a beautiful transparent protector that wraps around the rear of ZenFone Max Pro (M2) to keep it looking pristine. It's precision-molded using a material that's smooth to the touch and invisible to the eye, allowing the beauty of ZenFone Max Pro (M2) to shine through. It's also perfectly shaped for a snug fit, keeping your smartphone fully protected.
