https://techinstyle.asus.com/hub/mobile/
    ASUS ZenPower Max
    Back top
    Notebook-Charging 26,800mAh Power Bank
    60
    w
    USB-C charging
    26800
    mAh
     Battery Life
    2
    Ports
    Quick Charge
    ASUS ZenPower Max is the sldeek 26800mAh power bank that charges your notebook and smart devices in double-quick time. Featuring dual fast-charge ports and a reversible USB-C connector for up to three-up charging, ZenPower Max is not just for power — the powerful built-in LED torch shines a light wherever you need it!
    Ultra-High Capacity and USB-C Charging
    ZenPower Max's power-packed 26800mAh battery has enough juice to charge your smartphone or tablet fully, and several times over. And with the latest USB-C output built in, ZenPower Max is ready to charge almost any modern device — even a notebook computer!
    Quick Charge 2.0, Double-Quick Charging
    With ZenPower Max's dual-port Quick Charge 2.0 USB sockets you're able to charge two devices at the same time. With two devices connected, ZenPower Max outputs at up to 36W, and with just USB-C it delivers up to 60W — enough to charge power-hungry notebooks!
    total
    36
    w
    USB Outputs
    up to
    60
    w
    USB-C Outputs
    Less Time Charging,
    More Time Doing
    ZenPower Max is engineered for top speed, with both USB ports supporting the Quick Charge 2.0 standard — and that means charging that's up to 75% faster!
    All the Power You Need to Keep You Going
    ZenPower Max's built-in 26800mAh battery offers substantial capacity to keep not just one, but multiple devices charged and ready to go.
    over
    5.7
    times
    for ZenFone 3
    over
    5.9
    times
    for ZenFone 3 Deluxe
    over
    2.6
    times
    for ZenPad 3S 10
    over
    1.5
    times
    for ZenBook 3
    The Faster-to-Full Power Bank
    ZenPower Max comes with a high-power 33W charger to charge up to 330% faster than a traditional 5V/2A adapter — so it goes from empty to full is just 5.5 hours!
    up to
    330
    faster than 10W adapter
    5.5
    hrs
    Full Charge
    Protect Yourself and Your Device
    ZenPower Max's exclusive PowerSafe technology monitors temperature, controls both input and output voltages, and guards against short circuits to provide you with maximum safety while charging.
    1.8
    x
    Longer
    Lifespan
    60
    Temperature
    Protection
    6
    types
    International
    Certification
    types
    Protection
    ASUS PowerSafe Technology
    Temperature Protection
    Short circuit Protection
    Rest Protection
    Input Over Voltage Protection
    Output Over Voltage Protection
    Input Reverse Direction Protection
    Over Charge/ Over Discharge Protection
    Output Over Current Protection
    Cell PTC Protection
    JEITA Protection
    International Certification
    ZenPower Max has been certified by six leading international testing organizations, for safety, electromagnetic-interference (EMI) levels and fast-charge performance. It also conforms to both IEC 60950-1 and IEC 62133 standards — giving you the reassurance that it's ready for every circumstance.
    Your Ever-Ready Flashlight
    ZenPower Max does more than you can imagine — it's a high-intensity LED flashlight that sends a beam of super-bright light wherever you need it, having enough power to shine for up to 12 days!
    Tested to Perfection
    ZenPower Max is powerful and beautiful — and built to last! We put it through 5,000 USB-plug insertions and removals, subjected it to repeated extreme-temperature tests of between -40° and 70°C, and drop-tested it from pocket height of around 80cm, time and time again. ZenPower Max has been tested to perfection to survive everyday life!
    5,000
    Times
    USB Plug Test
    80
    cm
    Drop Test
    70
    Highest Temp
    -40
    Lowest Temp
    Everything You Need to Charge
    ZenPower Max is the only on-the-go charging solution you need, with everything included. You get a fast-charge adapter, USB cables, multiple interchangeable plugs for different devices, and a plush pouch for storage and transport!
