PadFone mini (PF451CL) Side Flip Cover
    Fashionable & Durable
    • Protects your screen and minimizes scratches, scrapes and dents. It features a soft microfiber inner cover and a durable polyurethane outer cover for maximum protection.
    • It can easily slip into the PadFone mini Station without the need to remove the Side Flip Cover. Intuitive and easy to use!
    • Replaces the existing back cover as a snap-on replacement.
    • Available in black
      Product Image
      The PadFone mini’s Side Flip Cover undergoes a series of durability tests, which include paint abrasion, resistance to impact, extreme temperatures, humidity and solvents. The inner layer is made of a fine microfiber cloth that keeps the screen safe from scratches and scrapes.
      Protective cover
      Snap-on replacement
      Replace the rear cover of your phone with a quick snap.
      1. Front cover textured durable microfiber interior and polyurethane exterior
