https://techinstyle.asus.com/hub/mobile/
    ZenFone 2 Laser Bumper Case (ZE550KL/ZE551KL)
    All-round colorful and easy fit
    • At just 1.2 mm thick, the ZenFone 2 Bumper Case provides adequate protection without compromising the smartphone’s lightweight design.
    • Its tactile thermoplastic polyurethane surface feels soft to the touch.
    • Snap-on design protects the rear of your ZenFone 2, while giving you full access its various ports.
    • ZenFone2 Bumper Case is available in Black, Orange, Yellow, and Aqua Blue.
      Product Image
      With its ultra-slim and lightweight design, the ZenFone 2 Bumper Case is tailor-made for your ZenFone 2. At just 1.2mm thick, the Bumper Case gives your ZenFone 2 adequate protection without compromising the smartphone’s slim lines, so it still fits easily in your pocket. Its tactile thermoplastic polyurethane surface feels soft to the touch. Available in Black, Orange, Yellow, and Aqua Blue, the Bumper Case lets you add that little bit of personal style to your ZenFone 2.
      Ultra-slim and light
      Tactile exterior
      Feels soft to the touch
      Well thought out design
      Fully access to all ports
      Vibrant color options
