ZenFone 2 Laser Slim Case (ZE500KG/ZE500KL)
    Ultra-slim, lightweight protection for your ZenFone 2
    • At just 1.4mm thick, the ZenFone 2 Slim Case provides adequate protection without compromising the smartphone’s lightweight design
    • Polyurethane leather cover is soft to the touch
    • Multi-layered, heat press construction techniques ensure a durable case that perfectly fits your ZenFone 2
    • Snap-on design protects the rear of your ZenFone 2, while giving you full access its various ports
    • ZenFone 2 Slim Case is available in Black, Orange, Yellow, and Aqua Blue.
      Product Image
      With its ultra-slim and lightweight design, the ZenFone 2 Slim Case is tailor-made for your ZenFone 2. At just 1.4mm thick, the Slim Case gives your ZenFone 2 adequate protection without compromising the smartphone’s slim lines, so it still fits easily in your pocket. It consists of several fabric layers heat pressed together – ensuring durability and a perfect fit for you ZenFone 2. Its tactile polyurethane leather surface feels soft to the touch, while its microfiber interior guards your ZenFone 2 against dust and scratches. Available in Black, Orange, Yellow, and Aqua Blue, the Slim Case lets you add that little bit of personal style to your ZenFone 2.
      Ultra-slim and light
      At just 1.4mm thick
      Tactile exterior
      Well thought out design
      Giving you full access its various ports
      Vibrant color options
