http://www.asus.com/lifestyle/zenfone/
    ZenFone 3 Deluxe Clear Case (ZS550KL)
    Back top
    Snap in for stylish protection
    ZenFone 3 Deluxe Clear Case is the beautifully transparent protector that wraps around the rear to keep your smartphone in pristine condition. And, because ZenFone 3 Deluxe Clear Case is totally translucent, the elegance of the antenna line free metal unibody shows right through — so your style is as clear as your protection.
    Precision-molded for the perfect fit
    ZenFone 3 Deluxe Clear Case is precision-molded using a material that's both smooth to the touch and invisible to the eye — and it's perfectly shaped for a snug fit.
    An invisible layer of smart protection
    ZenFone 3 Deluxe Clear Case's precision-molded shape is more than simply an aesthetic joy — it adds an invisible extra layer to the rear of your ZenFone 3 Deluxe to prevent scratches, deflect bumps and knocks, and keep your smartphone looking as smart as new.
