http://www.asus.com/lifestyle/zenfone/
    ZenFone 3 Laser View Flip Cover (ZC551KL)
    Back top
    Premium protection in intuitive fashion
    ZenFone 3 Laser View Flip Cover protects ZenFone 3 Laser's beautiful display from scrapes and scratches, makes important information and updates available at a glance, and has a luxurious design that's both great to hold and to show off.
    Embossed
    Leather
    Instant 7
    Notifications
    Premium
    Protection
    Luxurious embossed design
    With the look and feel of embossed leather ZenFone 3 Laser View Flip Cover is so comfortable to hold, complementing the natural warmth and comfort of your hand. And it's more than a desirable aesthetic — the rear etching provides great tactility for added grip.
    With the look and feel of embossed leather ZenFone 3 View Flip Cover is so comfortable to hold, complementing the natural warmth and comfort of your hand. And it's more than a desirable aesthetic — the rear etching provides great tactility for added grip.
    Updates at a glance
    With ZenFone 3 Laser View Flip Cover, you'll see all the information you need without having to open up the case – check the time, pick up incoming calls, or check notifications at a glance. It really is that easy.
    Updates at a glance
    Comfortable protection
    ZenFone 3 Laser View Flip Cover‘s soft polyurethane material is comfortable in your pocket, and protects your ZenFone 3 Laser from dust, dings and scratches.
