https://techinstyle.asus.com/hub/mobile/
    ZenFone 5 & 5Z Clear Soft Bumper (ZE620KL, ZS620KL)
    Transparent Beauty
    • Perfectly designed protection for your ZenFone 5|5Z
    • Prevents scratches to preserves the beauty of ZenFone 5|5Z and keep it in pristine condition
    • Comfortable to hold, made from elegant transparent material that shows off the full beauty of your ZenFone 5|5Z
      ZenFone 5|5Z Clear Soft Bumper is a beautiful transparent protector that wraps around the rear of ZenFone 5|5Z to keep it looking pristine. It's precision-molded using a material that's smooth to the touch and invisible to the eye, allowing the beauty of ZenFone 5|5Z to shine through. It's also perfectly shaped for a snug fit, keeping your smartphone fully protected.
