Back top Premium protection in intuitive fashion ZenFone Max View Flip Case protects ZenFone Max’s beautiful display from scrapes and scratches, makes important information and updates available at a glance. Embossed Leather Instant 7 Notifications Premium Protection Classic luxurious design With the look and feel of embossed leather ZenFone Max View Flip Case carries the warmth and comfort that mirror the touch of our hands. And it’s more than a desirable aesthetic — the rear etching provides great tactility for added grip! Updates at a glance With ZenFone Max View Flip Case, you’ll see all the information you need without having to open up the Case – check the time, pick up incoming calls, or check notifications at a glance. It really is that easy! Updates at a glance With ZenFone Max View Flip Case, you’ll see all the information you need without having to open up the Case – check the time, pick up incoming calls, or check notifications at a glance. It really is that easy! Comfortable protection ZenFone Max View Flip Case‘s soft polyurethane material is comfortable in your pocket, and protects your ZenFone Max from dust, dings and scratches.
