http://www.asus.com/lifestyle/zenfone/
    ZenFone 5 Rugged Case
    Tough protection for demanding use
    • An unintrusive, rugged case to guard the ZenFone against shocks, drops and dust.
    • Shock-absorbing silicone protects the ZenFone against bumps and drops from up to 1.5meters.
    • Rounded edges and a raised bezel shield the screen from impacts from all angles
    • Easy to assemble, three-layer protection comprising of two materials.
    • Perfectly fits your ZenFone 5 to give you access to all buttons and openings for the camera and ports.
    • Stylish design available in four colors.
      Product Image
      ASUS ZenFone 5 Rugged Case secures and protects your ZenFone wherever you go. Its reinforced silicone construction absorbs bumps and shocks to provide maximum protection against drops. Its rounded edges and three-layer design comprising of two different materials dissipate sudden impacts so you never have to worry about damaging your ZenFone. Its stylish design is available in four colors; and gives you easy access to all buttons as well as openings for the camera and ports.
      Raised Front Bezel
      Front polycarbonate frame features a raised bezel to protect the screen
      Covered Buttons
      The silicone jacket protects the buttons without compromising ease of use
      Clear Port Access
      Custom cutouts provide easy access to all device ports
      Full Shock Dissipation
      The Rugged Case features a silicone jacket layer sandwiched between a polycarbonate tray and front bezel. The outer edge of the silicone jacket creates a pathway for shocks to dissipate, protecting the device from multiple angles.
      1. Middle part: Silicone
        Absorbs bumps and shocks
      2. Front Frame/Bottom cover: PC
        Reduces sudden impacts
      Against drops
      Scratch and Scuff Resistant
      Polycarbonate cover protects your device from scratches and scuffs
