https://www.asus.com/lifestyle/zenpad/
    ASUS ZenPad 7.0 Power Case CB71 (Z370 Series)
    ASUS Power Case
    The World's First Back Cover with a Powerful Battery
    More power for your day
    ASUS Power Case extends ASUS ZenPad 7.0's battery life by up to 15 hours to easily get you through the day. Perfect for travelers, ASUS Power Case provides nonstop entertainment and productivity during long trips.
    UP TO
    14 hrs
    Battery life
    Elegant and convenient
    ASUS Power Case has a beautiful design with elegant, embossed leather patterning and a metallic frame that perfectly matches ASUS ZenPad 7.0's premium look while maintaining its compact size. ASUS Power Case seamlessly attaches to ASUS ZenPad 7.0 without adding bulk. It's thin and light so that you easily keep your ASUS ZenPad 7.0 charged wherever you go.
    On-screen battery indicator
    ASUS ZenPad 7.0 displays the current battery level of ASUS Power Case on its screen, so you will always know how much power remains.
    Smart protection for ASUS ZenPad 7.0
    Exclusive ASUS PowerSafe technology monitors temperature, controls both input and output voltages, and guards against short circuits to provide you with maximum safety while charging.
    Temperature
    Protection
    Short Circuit
    Protection
    Input Over Voltage Protection
    Output Over Current Protection
    Input Reverse Direction Protection
    Over Charge / Over Discharge Protection
    Cell PTC
    Protection
    Adapter
    Protection
    JEITA Protection
    (Temperature Protection)
