Chilly Vent
    Chilly Vent
    Dual Core Support for Over-clocking
    CPU Support
    AMD Athlon™64 FX/X2
    AMD Athlon™64 up to 4200+ (AMD Socket 754/939/AM2)
    Fan Speed 1,500~4,500 rpm ± 10%, Sensor Fan
    Material Cu. Base with Nickel Plating + Al. Fin + 2 Heat Pipes
    Advantages and Benefits
    Asus innovative design to increase heat dissipation area by 30%
    Patented clip for easier installation
    Nickel-copper pipes with Nickel-aluminum fins
    Unique & Patented Pending clip design
