Crux P4 MM7S
    Crux P4 MM7S
    Outstanding Performance with Affordability
    CPU Support Prescott 3.4G+ / all Northwood
    Fan speed 2000~5400 rpm ± 10%
    Material Aluminum extrusion with Copper inserted
      Features
      Application to Intel Socket 478 Prescott 3.4G+
      Patented heat sink for omni 4-way airflow
      1 ball bearing, ultra high-speed fan for power cooling
      Long life expectation
      Tool free and easy assembly
      Smart IC auto-detection sensor fan
      Buy the Best Mainstream Product with Superior High Performance and Affordability
      ASUS Crux P4 MM7S comes with the best combination of fan and heatsink. Even with Aluminum extrusion and Copper core, the performance of Crux P4 MM7S can compete with competitors' all-Copper solutions
      ASUS Innovation: Efficient "CRUX" Heat Sink Design
      Our thermal solutions are designed from users' point-of-view to ensure cool and stable system operation
      Efficient: Expand heat exchange area for better heat dissipation to all directions without any lose
      System stability: Omni-directional airflow design allows ventilation from all direction. The unique design cools down components around the CPU by 10~ 15°C and lowers overall system temperature for superior stability
      Omni 4-way directional airflow for VR thermal
      Why ASUS?
      Crux P4 MM7S' best performance provides the best mainstream choice for you instead of others' high cost of all-Copper solutions
      ASUS patented slim heat sink for omni 4-way airflow: 4-way heatsink to lower the temperature of CPU and VRM
      ASUS force-saving clip design, tool-free and easy assembly
