Lion Square
    Lion Square
    Φ8 heat pipes enable gamers to enjoy overclocking
    - Temperature 30% lower brings superior performance for Quad-Core overclocking
    - Inner PWM fan delivers quiet cooling at a mere 16 dBA
    - The spirit of sword lion brings good fortune with unfearing design
    Product Image
    F8 heat pipes enable gamers to enjoy overclocking
    ASUS Features
    Specific Design -The Legend for Sword Lion
    The ASUS Lion Square is named after the legend of the Sword Lion, which is the emblem of strength, courage and good fortune. The bold and unique design featuresF8 heat pipes that originate from the bottom of the device for heat conduction and adds aesthetic appeal with nuts on the top of the cooler cover that mimic the shape of the shield. Both technically and artistically, the Lion Square perfectly matches the spirit of the traditional sword lion, in the hope of providing the gamers an effective and safer operating experience, or even good fortune!
    About the legend:
    A famous general once led his armies to defeat a group of strong enemies after an invasion. The shields that were equipped by the armies were carved with a lion-tattoo and the swords were placed through lion’s mouth. Later generations believe that this lion-tattoo symbolizes Strength, Courage, and Good Fortune.
    Enable Large Heat Exchange Area and Powerful Cooling
    The Lion Square incorporates a nickel-plating copper base, four F8 copper heat pipes, aluminum wave fins and a 9cm LED inner fan to efficiently lower processor temperatures by 30%. In addition, the Inner fan directs airflow created by the 9cm LED fan to surrounding VRM (voltage regulation modules) – which is critical to processor operations and overall system reliability. These features enable gamers to enjoy safe overclocking of up to 180 W.
    Innovative Features for Convenience and Quiet Cooling
    The Lion Square incorporates several innovative features that include: a PWM function with the 9cm fan that automatically modulates fan speeds according to the CPU temperature – delivering quiet cooling at a mere 16dBA; while innovative assembly with specially designed spring screw and clips makes fastening easier than ever before. In just 2 simple steps, the Lion Square can be easily installed without removing the motherboard from the system.
    Quiet Cooling
