Silent Knight II
    Silent Knight II
    Pure Copper - Made for Quad-Core CPUs at Only 610g
    - 6 innovatively designed heat pipes increases heat transit capacity
    - Inner PWM fan delivers quiet cooling at a mere 25 dBA
    - Universal clip design for easier installation
    Product Image
    Advantages and Benefits
    Excellent Performance for Overclockers
    100% copper materials and six copper heat pipes ensure excellent heat dissipation for maximum cooling performance
    Universal Application
    The Silent Knight II supports the Intel® Core™2 Extreme/ Core™2 Quad (Quad-Core) CPU, Intel® Pentium® 4 LGA775 & AMD Athlon™ 64 X2 Dual-Core CPU, AMD Athlon™ 64(-FX) (939/940/AM2)
    Best Balance between Performance and Acoustic
    PWM function automatically adjusts rotation speed according to CPU temperature and delivers a quiet cooling at a mere 25dBA
    Reliable
    The fan positioned inside the frame and VRM shield guides cool air to critical components around the CPU for stable operation
    Why Thermal Matter
    Every 10°C up from 70°C will reduce CPU life time for about 1 year (Source: Intel)
    Every 10°C up from 120°C will reduce VR life time for about 50%
    Temperature over 100°C will cause Capacitors leakage or burned abnormally
    That´s why a good thermal solution makes system more stable and extends components´ life.
    High Cu. Fin Density for Great Heat Dissipation
    6 High Performance Heat pipes and copper base for fast heat transfer
    Elegant ASUS Fan Cover Design to maintain temperature for a stable
