Silent Square EVO
    Silent Square EVO
    Best Choice to Quad-Core CPU Support
    - Extremely quiet at a mere 22dBA
    - Waved fins enable maximum heat dissipation that lower CPU temp by 20-30%
    - Universal clip design for easier installations
    Product Image
    Advantages and Benefits
    Multiple Application with PWN Function
    Silent Square EVO supports the Intel® Core™ 2 Extreme/Core™ 2 Quad Quad-core CPU (LGA 775) and AMD Athlon™ 64 FX/X2 Dual-Core processors (939/940/AM2). PWM function automatically modulates 9cm fan speed according to CPU temperature and delivers a quiet cooling at a mere 22dBA.
    Inner Fan
    The fan positioned inside the frame for maximum airflow and VRM shield guides cool air to critical components around the CPU for stable operation.
    Fast Heat Transfer
    The "wave-shaped" double side fin design on both sides of the cooler for larger heat exchange area, and combined of the copper base and five copper heat pipes can efficiently transfer the heat to the fins, maintaining the temperature for high-performance computing and stable operation.
    Copper Base + 5 Heat Pipes for Better Heat Transfer
    Double Sides "Wave-Shaped" Fins for Effective Heat Dissipation
    Blue LED Fan - Stylize your PC
    Unique Ventilation Design to Integrated Cooling of Voltage Converters
    * 20% Lower VRM Temp
    * 30% Lower CPU Temp
    Best Performance & Low Acoustics
    Compared Competing Solutions
