Silent Square Pro
    Silent Square Pro
    Extremely Cool for Dual-Core CPU
    CPU Support
    Intel® Core™2 Extreme/ Core™2 Duo
    Intel® Pentium® D Dual-Core CPU
    Intel® Pentium® 4 LGA775 & Socket 478 CPU
    AMD Athlon™ 64 X2 Dual-Core CPU/ AMD Athlon™ 64 FX CPU
    Fan Speed 2,500 rpm
    Material Cu. Base + Dual-Side Al. Fins + 5 Heat Pipes
    Advantages and Benefits
    Superior Performance for Overclockers
    The Silent Square Pro incorporated a "wave-shaped" double side fin design on both sides of the cooler for larger hear exchange area.
    Quick
    Five copper heat pipes efficiently transfer heat to the fins, maintaining temperature for high-performance computing
    Universal Application
    The Silent Square Pro supports the Intel® Core™2 Extreme/ Core™2 Duo processor, Intel® Pentium® D Dual-Core CPU, Intel® Pentium® 4 LGA775 & Socket 478 CPU, AMD Athlon™ 64 X2 Dual-Core CPU, AMD Athlon™ 64(-FX)
    Aesthetics
    Stylish wave-shaped fins for effective heat dissipation
    Reliable
    The fan positioned inside the frame and VRM shield guide cool air to critical components around the CPU for stable operation.
    Easy Installation
    The patented retention module enables easy installation in three simple steps even without removing the motherboard from the system or memory modules from the board and regardless of the processor platform
    ASUS Drive Bay
    Enhanced performance and acoustic silence are the two chief considerations.
    The readable LCD shows fan-speed clearly at real time.
    Fan speed control on 3.5'' front panel is more convenient than the other control devices in markets.
    Click here for >> Compatible Motherboard List <<
