Triton 70
    Triton 70
    Best Choice for Slim PC
    - The second fan allowance design satisfies the gamers´ requirements
    - 20% space saving for installation
    - Thoughtful push pin and clip for easy installation without removing the MB
    Product Image
    Advantages and Benefits
    Mutiple Application with PWM Function
    Triton 70 supports the Intel® LGA775 and AMD™ K8 939/940/AM2 platforms. PWM function automatically modulates fan speed according to CPU temperature and delivers a quiet cooling at a mere 22dBA.
    Ideal Cooling with DIY Enjoyment
    Triton 70 provides the possibilities for users to shift 8 & 9cm Fans, also expandable for a second optional fan. Performance and silence at your control.
    *Connect 2nd optional fan by 3 to 4 pin connector with Power Supply cable will disable the PWM function.
    **In order to achieve better performance, it is highly recommended that the 2nd fan speed be higher than the 1st one.
    Smart Design on Installation
    Innovation in assembly with push pins and clip makes fastening easier than ever for both Intel and AMD users. No need to remove motherboard.
    User friendly
    Push Pin design for Intel LGA775 Platform
    Smart Clip design for AMD K8 & AM2 Platform
    Space-saving
    The Triton 70, light weight with small dimension, can save 20% space for users to choose for slim PC.
