Triton 75
    Triton 75
    Fanless design satisfies your DIY choice
    - Fanless design with space for 12cm fan gives user customization
    - Thoughtful push pin and clip for easy installation without removing the MB
    - Lightweight at only 395g places less stress on MB
    Product Image
    Fanless Design Satisfies Your DIY Choice
    Advantages and Benefits
    Mutiple Application
    Triton 75 supports the Intel® Core™ 2 Extreme/Core™ 2 Quad Quad-core CPU (LGA 775) and AMD Athlon™ 64 FX/X2 Dual-Core processors (939/940/AM2).
    Fan-less Design to Satisfy All Your Requirements & DIY Fun
    The Triton 75 is ASUS´ first fan-less designed model which is compatible to all 12 cm fans in the market. Gamers can choose any 12cm fan freely to satisfy their requiremenst and enjoy DIY fun.
    *Recommend fan dimension : 120 x 120 x 25(mm)
    *Recommend air flow : >45CFM
    Fast Heat Transfer
    Good combination of the copper base, fins and four copper heatpipes can efficiently transfer the heat to maintain the temperature for high-performance computing and stable operation.
    4 High Performance Heat pipes and copper base for fast heat transfer
    High Fin Density for Better Heat Dissipation
    Easy Installation
    Innovation in assembly with push pins and clip makes fastening easier than ever for both Intel and AMD users. No need to remove motherboard.
    Easy-to-Mount for Intel & AMD Platforms
    Time Saving and Tool Free
    User Friendly
    Intel LGA775 Platform
    AMD K8 & AM2 Platform
    Lightweight than ever Your Request
    The lightweight of Triton 75 is at only 395g that can place less stress on MB than ever
    Best Performance & Low Acoustics
    Compared Competing Solutions
